FAQBot
Community Admin
Community Admin
[LCD-M]How to adjust screen brightness and contrast?
Adjust the screen brightness and contrast according to what is displayed on the screen. Set the brightness based on your personal comfort level, avoiding settings that are too bright or too dark. Adjust the contrast appropriately; increasing it can improve image clarity, but excessively high contrast can make the image look unnatural. Maintain a balance.
Applicable to ASUS Monitor Series: PG/XG/VG Series
1.First, press the physical function buttonImage on the monitorBrightnessto adjust the brightness within the range of 0~100.
Select "Contrast" to adjust the contrast within the range of 0~100.
Note: A source video signal is required.
Applicable to ASUS Monitor Series: BE/VA/VP/VT/VU/VY/VZ/MB/MQ Series
1.First, press the physical function buttonColoron the monitor,Then, selectBrightness to adjust the brightness within the range of 0~100.
Applicable to ASUS Monitor Series:PA Series
1. First, press the physical function button "ProArt Palette" on the monitor. Then, select "Brightness" to adjust the brightness within the range of 0~100.
Question & Answer:
Question 1. Special Models: Brightness Adjustment for Portable Monitors MB168B/MB165B (No On-Screen Display Menu)。
Answer 1. For reference [LCD Monitor] Portable monitor MB168B/MB165B How to adjust the screen brightness?
Question 2. Why can't I adjust brightness and other color settings in sRGB mode on ProArt displays?
Answer 2. For reference [ProArt Display] Why can't I adjust the brightness and other color settings in the sRGB mode of the ...
*For limitations of scenario modes on each model, please refer to the user manual of the relevant model。
Version history
Last update:
‎10-07-2025 07:13 PM
Updated by:
