FAQBot
Community Admin
Community Admin
[LCD] ASUS ZenScreen Fold OLED MQ17QH Appearance and Usage Introduction
The ASUS ZenScreen Fold OLED MQ17QH is a 17.3-inch QHD (2560x1920) foldable OLED monitor with a 12.5-inch foldable display. It features the latest waterdrop-style hinge design, providing a seamless and ample screen space, making it suitable for both work and entertainment. It is lightweight and portable, making it easy to carry around. It offers multiple connectivity options, including mini-HDMI, dual USB Type-C ports, and a headphone jack. It also supports folding stands for both landscape and portrait modes. Additionally, it comes with a built-in standard tripod socket, making it compatible with any camera tripod available on the market.
Directory:
1. MQ17QH appearance introduction
2. MQ17QH connection method
3. MQ17QH usage method
4. MQ17QH cleanup method
5. Q&A
Front:
1. Power button/power LED
2. Menu button
3. Close button
4. Shortcut button
5. Headphones
6. Mini HDMI port
7. USB Type-C 1 port
8. USB Type-C 2 port
1. Use Mini-HDMI to connect to desktop/laptop computer
2. Use USB Type-C to connect to desktop/laptop computer
*Please confirm whether your laptop's USB-C port supports DP output function?
*When the power adapter of the USB monitor is not plugged in, the monitor relies on the power obtained from the computer (desktop/laptop) to operate. If the monitor detects insufficient power output from the computer, the brightness of the monitor will be lower. This is done to prevent the monitor from suddenly shutting down due to insufficient power. If higher brightness is required, plug the screen adapter in*
1.Please do not apply pressure around the hinge area. Due to the unique material of the hinge, applying pressure may damage its foldable design and panel display.
2.Please avoid folding or carrying this device as shown below. (Please control the maximum opening angle within 180 degrees)
4.MQ17QH cleanup method
1. Please avoid placing objects on MQ17QH. Please also avoid wiping the screen with water or alcohol.
2. Please use the product accessory microfiber cloth for cleaning, and please control the maximum opening angle of the MQ17QH within 180 degrees.
Note: The MQ17QH is not a touch screen or a handwriting display device. Please do not use a stylus or any sharp objects to make markings on the MQ17QH.
*Note: The MQ17QH is not a touch screen or a handwriting display device. Please do not use a stylus or any sharp objects to make markings on the MQ17QH.*
5.Q&A
Q1: What should I do when the power indicator light of MQ17QH is not lit up?
A1:1. Please press the power button and check if the display mode is set to " On "
     2. Check if the signal cable connecting the monitor and the computer is properly connected.
Q2: After connecting to a USB Type-C source device, does the power LED continue to flash or the ASUS logo display repeatedly?​
A2:1. Check whether the power adapter is used.​
     2. Please use original accessories Type-C cable and power adapter.
Q3: How to identify whether the laptop USB-C port supports DP output function?
A3: Please refer to the following related links:
      How to determine the USB Type-C® (USB-C) interface specifications of ASUS computers and whether it ...
Q4: Introduction to ASUS ZenScreen Stand MTS02D support stand?
A4: Please refer to related links:ASUS ZenScreen Stand MTS02D
Q5: How to install ZenScreen Stand MTS02D?
A5: Please refer to the related video linkASUS ZenScreen tripod (MTS02D) installation
Version history
Last update:
‎04-09-2025 06:58 PM
Updated by:
