on 03-30-2025 07:38 PM
[GU604V/G634J/GV601V] Troubleshooting - System stops responding after setting NVIDIA GPU only in NVIDIA Control Panel
If your laptop model is ROG Zephyrus M16 (2023) GU604V series, ROG Strix Scar 16 (2023) G634J series, or ROG Flow X16 (2023) GV601V series, users may encounter a frozen screen. This happens when users manually set the display to "NVIDIA GPU Only" in the NVIDIA Control Panel after they reboot the system.
If you have already encountered a frozen screen please refer to the troubleshooting steps below, and then update the NVIDIA driver to v31.0.15.2866 or above to prevent the issue happens again. You can learn more about How to search and download drivers.
In addition, if you want to toggle the MUX Switch manually, we recommend you do so from Armoury Crate by selecting the Ultimate GPU mode and rebooting the system. You can learn more about how the MUX Switch works here.
of the keyboard, and then press the Power button
to enter the BIOS utility. Here you can learn more about How to enter the BIOS utility.
If your problem is not solved with previous workaround information, please contact ASUS customer service center for further information.
