FAQBot
Community Admin
Community Admin
[Gaming NB] Self-cleaning Cooling System 2.0
Keeping the heatsinks free of debris is critical to maintaining optimal thermal dissipation. Our latest anti-dust measures channel particles away from the heatsink fins and other cooling components to prevent build-up over time. ASUS self-cleaning cooling system helps ensure consistent cooling performance over time. Our upgraded design features shorter anti-dust tunnels that leave more space around the fan, improving airflow by up to 15%. Preventing the buildup of dust on the heatsink fins and other cooling components ensures the long-term stability and reliability of your system.
Product supported
2021 all new ASUS Gaming laptop series, and please refer to ASUS official website for more products supported.
Feature Description
Inward Flow Self-Cleaing Cooling 2.0 Design
Additional air is channeled through the chassis, helping to accelerate heat dissipation and lower overall system temperatures.
Upgraded Arc Flow Fans Design
Upgraded Arc Flow fans feature 84 blades shaped to increase airflow by up to 13% and reduce noise by up to 3dB below previous gen designs. Laptop fan blades are typically uniform in size and shape, but ours vary in thickness, tapering down as low as 0.1mm at the base and flaring at the ends to draw in more air per rotation. Their anti-resonance design includes custom tips arranged in an aerodynamic wave pattern that guides airflow around the fan and keeps it balanced from blade to blade. Steady airflow reduces turbulence to lower noise and keeps cooling reliable over time.
Bionic Anti-Resonance Design Inspired by Nature
Our new Arc Flow fans were inspired by the most aerodynamic designs found in nature. Each blade is capped with a tip that helps regulate airflow, the same way that a bird’s feathers are tipped to direct air and keep the bird balanced in flight. The blade caps are also positioned in a wave pattern that is inspired by the undulating way that fish swim; the wave pattern better guides the flow of air around the fan and maximizes efficiency. Altogether, this design reduces turbulence and regulates airflow to lower noise and improve long-term reliability.
Version history
Last update:
‎04-10-2025 11:51 PM
Updated by:
