on 04-10-2025 11:50 PM
[Gaming NB] Active Aerodynamic System Plus (AAS+)
●What is AAS+?
In order to maximize the performance of ultra-thin gaming laptops, the cooling system becomes more important. ROG newly designed AAS Plus system uses our classic active aerodynamic system, opening a larger 28.5mm air intake behind the second screen to inhale cooler air and reduce noise.
The new AAS Plus is combined with many new heat dissipation technologies (such as using liquid metal for heat dissipation on the CPU), it can maintain the laptop in high performance. Base on the different tasks processing, ROG Armoury Crate application will switch seamlessly between different operating modes to optimize heat dissipation and noise.
●Model supported
Support ROG Zephyrus Duo 15 Series of gaming laptop (GX550& GX551 Series),please refer to ASUS ROG Official Website for more details.
●Feature Description
ASUS ROG origination design Active Aerodynamic System (AAS), lifted to expose a small vent beneath the chassis. AAS Plus pushes that concept further, opening up a 28.5mm high air intake behind the tilted secondary display that increases airflow by 30%. Instead of drawing in air from below where warmer components have a greater effect on intake flow, allowing our fans to draw cooler air from above. The larger space also helps keep lowrer noise levels , and giving a quieter gaming experience.
