on 04-11-2025 12:27 AM
[Graphic Card] Condition of Fan Start and Fan Stop on RTX30 & RTX40 & RTX50 series
RTX 3090 RTX 3080 RTX 3070 RTX 3060 Ti Fan Start GPU Temperature is higher than 55 degree
or Wattage is higher than 100WGPU Temperature is higher than 55 degree
or Wattage is higher than 100WGPU Temperature is higher than 52 degree
or Wattage is higher than 100WFan Stop GPU Temperature is lower than 50 degree AND
-Wattage is lower than 50 watt AND
-0dB Fan mode is switched "on" in GPU Tweak IIGPU Temperature is lower than 50 degree AND
-Wattage is lower than 40 watt AND
-0dB Fan mode is switched "on" in GPU Tweak IIGPU Temperature is lower than 48 degree AND
| RTX 4090/4080/4070TI/4070/5000 series | |
| Fan Start | GPU Temperature is higher than 55 degree or Wattage is higher than 100W |
| Fan Stop | GPU Temperature is lower than 50 degree AND -Wattage is lower than 50 watt AND -0dB Fan mode is switched "on" in GPU Tweak II |
Note: Actual Wattage and Temperature may vary depending on product configuration, usage, operational conditions and power management settings.
