on
11-20-2023
09:57 PM
- edited on
03-06-2024
11:23 PM
by
ROGBot
[ROG Throne Qi] Charging Instructions
[ROG Throne Qi] Can all Qi devices be charged by ROG Throne Qi? If so, how?
[ROG Throne Qi] Can iPhone be wireless quick-charged with ROG Throne Qi?
[ROG Throne Qi] Can ROG Phone be charged with ROG Throne Qi?
[ROG Throne Qi] Do the AC adaptor and USB cable need to be connected to enable Qi charging?
[ROG Throne Qi] Is the ROG Throne Qi headset stand compatible with all headsets?
[ROG Throne Qi] What do the different indicator lights mean?
Yes, you can charge all Qi-enabled devices with the ROG Throne Qi headset stand. Place the charging surface of your device near the ROG logo on Throne Qi for the best charging efficiency. The blue indicator on the front of the headset stand will blink while your device is charging.
Yes, ROG Throne Qi can support up to 7.5W wireless charging so you can charge the iPhone with ROG Throne Qi.*
* Note: iPhones running above iOS 13 won't be able to activate quick charge since Apple blocks this function provided by the 3rd-party wireless charging device. User can only use regular 5W adapter to charge the iPhone.
No, ROG Phone cannot be charged with ROG Throne Qi because ROG Phone does not support wireless Qi charging.
The AC adaptor must be connected to activate the wireless Qi charging. If you want to turn on RGB lighting or connect your headset to ROG Throne Qi to listen to music, the USB cable must be connected to your PC.
You can connect any headset with a 3.5mm connector to ROG Throne Qi and enjoy the audio upgrade provided by the ESS 9118 DAC and amplifier. USB headsets can also be connected to ROG Throne Qi, but the audio will not be processed by the ESS 9118 DAC and amplifier.
Blue light blinking: Your device is charging
Blue light static: Your device is fully charged
Red light static: Standby (Ready to charge your device)
Red light blinking: Error (Unable to charge your device)
