on 10-07-2025 07:46 PM
[Mouse] ROG Harpe II Ace FAQs
ROG Harpe II Ace delivers true 8K performance with the latest ROG SpeedNova 8K wireless technology. It ensures a more stable 4K and 8K polling rate environment while reducing power consumption—achieving peak responsiveness without the need for a polling rate booster. Designed for competitive gamers, it offers unmatched consistency and immersion.
Q&A
Q1: What’s the difference between SpeedNova 8K and the original SpeedNova?
A1: ROG Harpe II Ace uses the latest-generation MCU to achieve SpeedNova 8K, which provides even more stable and responsive performance. SpeedNova 8K can also achieve 8K polling rate with no booster required.
Q2: Does it support the Omni Receiver one-to-two pairing feature?
A2: No, Harpe II Ace does not support the Omni one-to-two pairing feature. Since it’s using a newer MCU than older models, it can not pair with dongles from other devices, and other devices also cannot pair with its dongle either.
Q3: Can I change the optical switches in the Harpe II Ace?
A3: No, the Harpe II Ace doesn’t have hot-swappable switches. We left that out to cut down on weight to make it as light and competitive as possible.
Q4: Can I use Armoury Crate with the Harpe II Ace?
A4: Harpe II Ace device settings are only available via Gear Link , and only when connected via 2.4 GHz wireless or wired mode. However, Harpe II Ace still supports cross-product features such as Aura Sync within the Armoury Crate.
Aw no ... So I see that the Harpe ACE Mini uses only SpeedNova (non 8k) requiring a polling rate booster. Does this mean that the Harpe ACE Mini, even though is utilizing the same sensor as Harpe II ACE, is also using a different MCU? Meaning the features that have released on Harpe II ACE (single digit DPI increments, angle adjustment, etc) won't become available to Harpe ACE mini in a potential FW update?
