FAQBot
Community Admin
Community Admin
Gear Link FAQ
Gear Link is a fast, web-based tool that helps you to set up and customize your devices. Adjust key functions, lighting effects, and more — all without the need to downloads, so you're up and running in no time.
1. Compatible Device
1.1 Keyboard
ROG Azoth X
1.2 Mouse
ROG Keris II Origin
2. Compatible Browser Engine
2.1 Compatible Operating Systems
Windows 10, Windows 11, MAC OS
2.2 Compatible Browser Engines
Google Chrome
Microsoft Edge
3. Device Connection Instructions
How to Connect My Device to Gear Link?
Follow the steps below to connect your device to Gear Link:
Step 1: Ensure your device is connected to the system via a USB cable or RF 2.4GHz receiver
Step 2: Open Gear Link and click the “Connect” button
Note: When connecting a compatible device for the first time, please tap "Allow".
(The screen will only appear the first time a device is connected via USB cable or RF 2.4 GHz receiver, as Gear Link requires permission to connect to the device.)
Step 3: Select a device that is compatible with Gear Link
Step 4: Click the “Connect” button
Step 5: You can now access the device page to configure your device
4. Function Compatibility
4.1 Support Functions
Note: "N/A" indicates the absence of detailed settings.
4.2 Unsupported Functions
Certain features are currently not supported and will be made available through future extensions. Please stay tuned for upcoming updates as we strive to continuously improve the user experience.
To use the following features, please refer to Armoury Crate FAQ
4.3 Gear Link Removed Functions
5. Q&A
Q1: Does Gear Link Support Device Configuration via Bluetooth?
A1: Gear Link does not currently support device configuration via Bluetooth.
To set up your device with Gear Link, you must first connect via a USB cable or RF 2.4GHz receiver. Once the setup is complete, you can switch to a Bluetooth connection if your device supports it.
Q2: Does Gear Link Support Usage Without an Internet Connection?
A2: Yes, but please note that the following conditions must be met:
1. The device has already been successfully connected, and permission has been granted.
2. The browser must remain open and stay on the device page.
Comments
BearManPig
i don't know if anyone has asked this or thought of this but could there be a change and the whole full-featured Armory Crate ever be web-based so like u don't have to download the app? you could put in like your devices manufactures code and other info needed and then access all the features such as the power modes and such? i could see the website needing permission to change the settings and such on the laptop which would be 100% A ok. just a thought i had
Version history
Last update:
‎04-12-2025 10:16 AM
Updated by:
