FAQBot
Community Admin
Community Admin
[Accessories] Customer Induced Damage (CID) criteria
ASUS does not warrant uninterrupted or error-free operation of this Product. The warranty only covers technical hardware issues during the Warranty Period and in normal use conditions. It applies to firmware issues but not to any other software issues or customer induced damages or circumstances such as but not limited to:
For more warranty information, please refer to the ASUS Product Warranty Card:
 Product Warranty Information:
  Mouse/keyboard
  Headset/Microphone
  Other Accessories
Note: The following images are for reference only.
Keyboard legs- damaged
Key Shaft- foreign objects or liquid Inside
Keycap- damaged
Key switch- fracture
USB CABLE- damaged
Cable- broken
Mouse Right/Left Key- broken
Dongle- broken
Housing- broken
Connector- damaged
Keyboard legs-damaged
Damage  Comments
Keyboard legs damagedThe rubber is peeled off or wrapped, the anti-slip function will not work.
Damage  Comments
Keyboard legs damagedKeyboard legs crack due to external force
Damage  Comments
Keyboard legs damageThe rubber is peeled off or wrapped
Damage  Comments
Key Shaft foreign objects or liquid InsideThe presence of foreign objects or liquid on the keyboard shaft interior has caused malfunction.
Damage  Comments
Key Shaft pin bentSwitch pin bent, scratched or damaged on the switch slots.
Keycap- damaged
Damage  Comments
Keycap damagedInterior keycap crack due to external force
Damage  Comments
key switch fractureExternal forces caused broken hooks
USB CABLE- damage
Damage  Comments
USB cable damageA bent or deformed USB cable caused malfunction
Cable- broken
Damage  Comments
Cable BrokenA broken plug or connector caused malfunction
Damage  Comments
Hook- brokenThe broken hook of the left or right key affects the press feeling and gap
Dongle- broken
Damage  Comments
Dongle brokenThe dongle housing was separated from the device
Housing- broken
Damage  Comments
Housing BrokenThe housing was separated from the device
Connector- damaged
Damage  Comments
Connector damagedThe connector is damaged due to the forced insertion or removal of external devices.
Version history
Last update:
4 weeks ago
Updated by:
Contributors
