MoKiChU
Level 40
135 REPLIES 135
Works here & was easy 1 click update for me.
Troubleshooter & overclock your 386 Cyrix cpu anyday
Emir_Misel
Are You on Windows 23H3 or 24H2? It chould be with 24H2, which is buggy.
Thanks
Hulk Beast
23H2 here.
I would Not recommend using latest Windows major update. Wait until next update. Many drivers not yet advised on 24h2 don`t recognize the version & you get left out without anyone behind the wheel.
I only recently updated to 23H2.
like?
Learn, Play Enjoy! We help and collaborate, NOT complain!
Emir_Misel
Ahhh, that explains why, then, as I've done a fresh installation of 24H2, I have to go back to 23H2. Thank You
Hulk Beast
RyanBlakeIT
I'm running Windows 10 22H2 (I know it's technically not supported, but the previous driver worked).  In any case, after updating I am getting a failed to start in my Device Manager as well.  Intel APO is also reporting that it failed to connect now.  Previous drivers did work.  Cleared old drivers with Driver Explorer, uninstalled Intel APO, installed new drivers, and reinstalled Intel APO, but still no joy.
Ryan Blake - IT Leadership Professional
Asus ROG Crosshair X870E Hero Motherboard - AMD 9800X3D - Corsair RM1000x - G.SKILL Trident Z5 Royal Neo Series (AMD Expo) DDR5 RAM 32GB (2x16GB) 6000MT/s CL28-36-36-96 1.40V (F5-6000J2836G16GX2-TR5NS) - 1x Samsung 990 Pro 2TB & 1x Samsung 990 Pro 4TB SSDs - PNY GeForce RTX 4090 - Windows 11 Pro x64 24H2
If it helps anybody, the latest DTT drivers are working OK for me with Win 11 Pro 23H2. All of my drivers are up to date with MoKiChU releases and everything is running well. The only thing that isn't up to date is my BIOS. I'll try 3901 when not in Beta.
Z690 Hero, 12900K, BIOS 4301, MEI 2517.8.1.0, ME Firmware 16.1.38.2676, 7000X Case, RM1000x PSU, ASUS TUF OC 3090TI, 2 x 16GB Corsair RAM @ 5200MHz, Windows 11 Pro 23H2, Corsair H150i Elite AIO, 4x Corsair RGB fans, 3x M.2 NVME drives, 2x SATA SSDs, 2x SATA HDs.
Hello @JohnAb !  I actually broke bad and installed the beta BIOS (since you can downgrade it) after I backed up my settings to USB.  It's actually fine and I haven't seen any major performance degradation.
Same here John. I download the file, go to bios activate the DTT, f10. Enter bios extract install in adm. the pc restart and then go to app pin it and done. all is ok. I am on the beta bios. looks fine to me. BUT! i am on 24h2 insider prerelease clean install. with same drivers mentioned.  if that does something with those games good for them. i do not own none of those. But is there on my apex.
