11-04-2021 01:35 PM - last edited a week ago
Hi everyone,
- Intel ME Consumer Firmware :
Check/Update Process :
Check current version : Right click on "Check.cmd" > Run as administrator
Install/Update : Right click on "Install.cmd" > Run as administrator > Automatic restart when install is done
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Motherboards with Intel H610/B660/H670/Z690/B760/H770/Z790 chipset.
02-19-2025 12:58 PM
thanks for reply,
my drivers, DTT On and bios 2801 are updated like on your screenshots and i can't understand why apo doesn't work anymore since ME and MEI update because before those update it worked (did try both dtt/ipf drivers, uninstalling apo). driver store explorer
02-19-2025 01:42 PM
Try this BY THE LETTER.
I think i read all of it, appears to have some missing stuff and old ones there also. Not sure letters are so small.
There are some intel with odd number. and i am on z690 and 12th. but even my numbers are higher on some. check
i know you are on amd gpu.
but your numbers are lower on most
enter bios disable the apo and f10 check what need to be clear. instruction on the photo. win+r %temps% delete all delete trashcan and restart and try again. then go to bios activate (it should be 2 missing drivers on device manger) let see if that help. I use all drivers from forums.
hope this help a little
02-19-2025 04:04 PM
I used this method with the drivers dtt 44281 on the asus site and also with the drivers dtt 52187 of this forum which is more recent same result with apo failed to connect whereas I did not have problems before this update of the drivers MEI and ME.
i saw the message about the removal of the dtt 54113 driver, apparently there is the dtt 54373 available but i have the impression that they are reserved for the core ultra.
i also saw the message for the icls driver and i don't allow windows to update the drivers.
in short i'm going to contact asus support.
thanks for everything.
05-28-2025 04:48 AM
Edit: I did a new fresh install of windows 24H2 and it's all good man
04-24-2025 08:27 AM
Hey, mokichu, please is there any way how to downgrade ME firmware? I recently update to version 16.1.35.2557 for my asus z790-e gaming wifi II, but my system is not stable anymore. Thanks for reply 🙂
05-27-2025 11:25 PM
I also need to downgrade my ME to the previous version 16.1.32.2473.
05-28-2025 05:12 AM
asus officialy support 16.1.35.2557 on new 2001 bios, evetyhing works flawlesly 🙂
05-28-2025 05:09 AM
All good now 🙂 this fw is included in new 2001 bios on asus web :)))
04-28-2025 04:30 AM
rog z790-a d4 was broken,earlynextmotherBord
07-06-2025 10:35 PM
next motherBord is tuf gaming Z790 wifi d5
