[FIRMWARE] Intel ME (H470/Z490)
MoKiChU
Level 40
Hi everyone,
- Intel ME Consumer Firmware :
Firmware : 14.1.77.2497 [19/02/2025]
PMC Firmware : 140.2.01.1018
PCHC Firmware : 14.0.0.7002
PHY Firmware : 12.14.215.2015
Download : Link
Check/Update Process :
Check current version : Right click on "Check.cmd" > Run as administrator
Install/Update : Right click on "Install.cmd" > Run as administrator > Automatic restart when install is done
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Motherboards with Intel H470/Z490 chipset.
243 REPLIES 243
Ataemonus
Level 11
I flashed the OP file, works perfectly.
In the meantime, I learned that my way of building the image file for flashing was wrong, worked on the v12 firmware version, but not on the v14, so I now know the correct way.
Thank you @MoKiChU
Very strange
Thanks for this. Latest ME firmware updated successfully on TUF GAMING z490-PLUS.
I'm confused the Check.cmd are not included in the download - can I see what FW I have in a other way?
Bios
@rstolpe1988:
Yes, you can check the firmware version without rebooting to BIOS, if you run this from the command-line in the same folder as the firmware update:
FWUpdLcl64.exe -FWVER
The "-FWVER" switch makes the update executable output the currently installed firmware version without changing anything.
does it matter if the driver doesn't match the firmware # IE as on my mother board support page
We suggest you update ME Driver to the latest Version 14.1.51.1528 simultaneously
and mine has 2047.100.0.1039 driver and Firmware : 14.1.53.1649 on a ROG MAXIMUS XII HERO (WI-FI) thanks
Hi, pls update Intel ME Consumer v14.1.65.1990 if it's already out. The corporate version is still out.
Version v14.1.65.1969 has a serious problem with boot loop when booting on the motherboard Maximus XII Hero with I9-10900K. Thank you very much.
can't see anything from this post.
