[FIRMWARE] Intel ME (H470/Z490)
MoKiChU
Level 40
Hi everyone,
- Intel ME Consumer Firmware :
Firmware : 14.1.70.2228 [13/02/2023]
PMC Firmware : 140.2.01.1018 [22/02/2021]
PCHC Firmware : 14.0.0.7002 [12/06/2020]
PHY Firmware : 12.14.215.2015 [25/08/2021]
Download : Link
Check/Update Process :
Check current version : Right click on "Check.cmd" > Run as administrator
Install/Update : Right click on "Install.cmd" > Run as administrator > Automatic restart when install is done
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Motherboards with Intel H470/Z490 chipset.
235 REPLIES 235
Yuniel
wrong thread
MoKiChU
Level 40
Tekamine wrote:
Anyway, thank you Mokichu ! Is it physically possible, in your opinion, to upgrade the Z490 on the 15.1.XXXX versions, or is it strictly reserved for the Z590 boards ? (out of curiousity).
Thanks !
No, it's not possible, and even if it were possible there would be no interest/gain in doing so.
GettnBetter
This latest ME firmware fixed my issue with a Z490-E Gaming mobo. I updated to the 2601 firmware also. Everything working perfect again!
yeap 14.1.65.1990 firmware and 2601 bios work perfect , no security problem and no bootloop 😉 , the only problem is after update the bios have to set up again the fans curves , XMP lol but i made a video before reset the bios to know how i have it before the update 🙂
Ah you had an issue as well for the fan curve ? I was wondering why my fans were so loud :o. Though my curve didnt change at all after the update, but remaking it as it was by resetting the point made it work.
Yuniel
mokichu i want say thanks you for supporting us in the firmware 🙂 , beacuse asus dont even bother in keep update firmware even drivers about our motherboards
thanks to you last ME firmware 14.1.65.1990 and the bios 2601 (i think is the only asus keep on update is the bios's) , my machine work perfect no vulnerable and no bootloop or anything , thanks for taking time in working / developing software updates , i guess you are software engineering
MoKiChU
Level 40
Hi everyone,
Firmware : 14.1.65.1990 [11/05/2022]
Firmware PMC : 140.2.01.1018 [22/02/2021]
Firmware PCHC : 14.0.0.7002 [12/06/2020]
Firmware PHY : 12.14.215.2015 [25/08/2021]
Download : Link
Thread updated.
MoKiChU
Level 40
Hi everyone,
In order to anticipate questions, 14.1.65.1990 version has been reposted because the Firmware PHY has been updated.
MoKiChU wrote:
Hi everyone,
Why the date of this updated PHY is 25/08/2021 then?
MoKiChU
Level 40
This is not the release/update date, this is the Intel internal build date.
The 14.1.65.1990 ME firmware version previously posted contained this PHY firmware version : 12.14.214.2014 [01/04/2021]
