04-26-2020 06:56 AM - edited 01-03-2025 08:45 AM
Hi everyone,
- Intel ME Consumer Firmware :
Check/Update Process :
Check current version : Right click on "Check.cmd" > Run as administrator
Install/Update : Right click on "Install.cmd" > Run as administrator > Automatic restart when install is done
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Motherboards with Intel H470/Z490 chipset.
07-20-2022 09:52 PM
itsnice4u wrote:
After flashed 14.1.65.1990, the double boot(Qcode 19) or post loop issue with 14.1.65.1969 was fixed.
Thank you, Mokichu
07-20-2022 11:46 PM
Tekamine wrote:
@itsnice4u, which bios you are on atm ? wich mobo as well please ?
I have a Formula XII and a 2601 Bios, with the 1969 firmware. I am experiencing a triple boot issue since I've updated the Bios from 2409 to 2601, the 1969 firmware being already installed when I flashed.
I will give a shot to update to the new one. Just hoping it won't provoke any boot loop issues...
I ll keep you updated, especially concerning the bios section such as TjMax and FCLK frequencies.
07-21-2022 01:16 PM
07-21-2022 12:26 PM
07-21-2022 04:31 PM
07-25-2022 11:35 PM
08-01-2022 01:10 AM
Tekamine wrote:
Anyway, thank you Mokichu ! Is it physically possible, in your opinion, to upgrade the Z490 on the 15.1.XXXX versions, or is it strictly reserved for the Z590 boards ? (out of curiousity).
Thanks !
08-05-2022 10:34 AM
