[DRIVERS] Realtek USB Audio (AMD 5xx/6xx/TRX40 & Intel 5xx/6xx/7xx)
MoKiChU
Level 40
Hi everyone,
- Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) :
Drivers : 6.3.9600.2379 WHQL [21/02/2024]
DTS APO4x Extension Driver : 1.14.0.0 WHQL [17/12/2023]
Download : Link
- Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS Legacy) :
Drivers : 6.3.9600.2355 WHQL [09/03/2023]
SS3-SSVM Extension Driver : 1.3.18.0 WHQL [13/07/2022]
SS3-SSVM VAD Media Driver : 1.0.3.0 WHQL [07/06/2022]
SS3 APO AudioProcessingObject Driver : 3.7.0.0 WHQL [20/02/2024]
Download : Link
ASUS ROG SS/SS3|DTS Sound Unbound motherboards :
Install/Update Process :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Sonic Studio/Radar III, DTS Sound Unbound installed /!\
Uninstall them (Start > Settings > Apps) then restart your PC
Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
a-volute | avolute | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button
Launch SS3 Cleaner by right-click Run as admin
Press Windows key + X > "Device Manager" > "View" > Check "Show hidden devices" > "Sofware components" category
Uninstall these hidden devices by right-click Uninstall device (if you find them) then restart your PC :
DTS Audio Effects Component | DTS APO4x Service Component
INSTALL
Launch "Install.cmd" by right-click Run as admin > Automatic restart when install is done
Go in "Apps" folder > Install your apps from the Microsoft Store shortcuts
UPDATE
Note : Your apps will be updated automatically via the Microsoft Store.
- Realtek USB Audio Drivers (UAD - ASUS PRIME DTSX Ultra) :
DTS APO4x Service SoftwareComponent Driver : 1.14.9.0 WHQL [31/01/2024]
DTS APO4x Core AudioProcessingObject|SoftwareDevice Driver : 1.14.2.0 WHQL [03/01/2024]
DTSX Ultra HSA SoftwareComponent Driver : 1.11.5.0 WHQL [06/07/2023]
Download : Link
ASUS PRIME DTS:X Ultra motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS:X Ultra installed /!\
Check the box "Force Deletion" then click on the "Delete Driver(s)" button then restart your PC
INSTALL
UPDATE
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements (AMD - AM4/AM5) : ASUS ROG motherboards with AMD 5xx/6xx series chipsets with ALC40xx codec.
Hardware requirements (AMD - sTRX4) : ASUS ROG/PRIME motherboards with AMD TRX40 chipset.
Hardware requirements (Intel) : ASUS ROG motherboards with Intel 5xx/6xx/7xx series chipsets with ALC40xx codec.
Note : In order to know which drivers package to use, match the audio specifications of your motherboard with the apps or ask me.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
If you experience crackling, popping, audio stutter
Disable hibernation (Fast Startup included).
820 REPLIES 820
ksenchy
For installing latest realtek audio control, you can use offline install zip from here:
https://github.com/pal1000/Realtek-UAD-generic/releases
For some reason, MS store is not updating mine to 1.51, but this worked
Are you talking about this?
Yeah mine hasn't updated if there is an update. What are the changes?
MoKiChU
Level 40
Hi everyone,
Thread updated.
Sorry if you have been asked before but on the Realtek USb audio install instructions I noticed there are full cleanup and also update instructions.
Maybe I'm reading it wrong but do you have to do a full cleanup every time or after you have done a full clean up before can you just follow the update instructions?
Also do you know where to find the release notes for these audio updates?
You've just been complaining about MoKiChU's drivers and now you want help?
Z690 Hero, BIOS 3401, MEI 2406.5.5.0, ME Firmware 16.1.30.2361, 7000X Case, RM1000x PSU, i9 12900K, ASUS TUF OC 3090TI, 2 x 16GB Corsair RAM @ 5200MHz, Windows 11 Pro 23H2, Corsair H150i Elite AIO, 4x Corsair RGB fans, 3x M.2 NVME drives, 2x SATA SSDs, 2x SATA HDs.
Raicha
Hi. May I ask which version should I install for Z790-F WiFi II ? Thanks
You have an ASUS ROG SS|DTS Sound Unbound motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) from the first post of this thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
MoKiChU
Level 40
Hi everyone,
- DTS APO4x Extension Driver have been updated for these drivers packages :
Drivers : 6.3.9600.2355 WHQL [09/03/2023]​
Thread, post & drivers packages updated.
Thechin
Are there ever any release notes with these audio driver updates?  Evertime I update I never hear the audio get any better and a few times it got noticeably worse with static and crackling.
I've tried using the MSI interrupts tool a couple times but since I don't know exactly what it or I'm doing I feel the odds of making it even worse is high.
I've tried the Z790-H and MSI Edge Z790 both have awful audio issues with static and crackling. It seems like the new boards are just all bad. I'm going to try Asrock shortly
