[DRIVERS] Realtek USB Audio (AMD 5xx/6xx/8xx & Intel 5xx/6xx/7xx/8xx)
MoKiChU
Level 40
Hi everyone,
- Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) :
Drivers : 6.4.0.2402 WHQL [14/10/2024]
Dolby Extension Driver : 9.524.657.1 WHQL [23/05/2024]
Dolby HSA SoftwareComponent Driver : 3.30704.740.0 WHQL [02/09/2024]
Download : Link
ASUS ROG Realtek|Dolby Atmos motherboards :
Install/Update Process :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Dolby Access installed /!\
Uninstall them (Start > Settings > Apps) then restart your PC
Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
a-volute | avolute | dax | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button
INSTALL
Launch "Install.cmd" by right-click Run as admin > "Next" > The installer will ask you to restart your PC > "Finish"
Go in "Apps" folder > Install your apps from the Microsoft Store shortcuts
UPDATE
Launch "Update.cmd" by right-click Run as admin > Restart your PC when the command prompt window disappears
Launch Driver Store Explorer > Click on the "Select Old Driver(s)" button > Click on the "Delete Driver(s)" button
Note : Your apps will be updated automatically via the Microsoft Store.
- Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) :
DTS APO4x Extension Driver : 1.14.1.0 WHQL [22/05/2024]
Download : Link
ASUS ROG SS|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS Sound Unbound installed /!\
INSTALL
(You need to install Armoury Crate to install/use the SS drivers/app)
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) :
SS3 Extension Driver : 1.4.0.0 WHQL [17/04/2023]
SS3 AudioProcessingObject Driver : 3.7.2.0 WHQL [20/06/2024]
Download : Link
ASUS ROG SS3|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Sonic Studio/Radar III, DTS Sound Unbound installed /!\
Launch SS3 Cleaner by right-click Run as admin
Press Windows key + X > "Device Manager" > "View" > Check "Show hidden devices" > "Sofware components" category
Uninstall these hidden devices by right-click Uninstall device (if you find them) then restart your PC :
DTS Audio Effects Component | DTS APO4x Service Component
INSTALL
Update your SS3 apps : Sonic Studio III v3.16.24.0 | Sonic Radar III v3.16.24.0
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS PRIME DTSX Ultra) :
DTS APO4x Service SoftwareComponent Driver : 1.14.19.0 WHQL [04/09/2024]
DTS APO4x Core AudioProcessingObject|SoftwareDevice Driver : 1.14.11.0 WHQL [22/08/2024]
DTSX Ultra HSA SoftwareComponent Driver : 1.11.6.0 WHQL [30/04/2024]
Download : Link
ASUS PRIME DTS:X Ultra motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS:X Ultra installed /!\
a-volute | avolute | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button then restart your PC
INSTALL
UPDATE
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements (AMD) : ASUS ROG motherboards with AMD 5xx/6xx/8xx series chipsets with ALC40xx codec.
Hardware requirements (AMD - sTRX4) : ASUS ROG/PRIME motherboards with AMD TRX40 chipset.
Hardware requirements (Intel) : ASUS ROG motherboards with Intel 5xx/6xx/7xx/8xx series chipsets with ALC40xx codec.
Note : In order to know which drivers package to use, match the audio specifications of your motherboard with the apps or ask me.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
If you experience crackling, popping, audio stutter
Disable hibernation (Fast Startup included).
1,043 REPLIES 1,043
ms4
Hi, which driver should i download for ROG STRIX Z790-A GAMING WIFI?
denn73
Followed your instructions and updated to newest Realtek USB Audio driver but still getting crackling, popping, buzzing noises from both front and rear audio out ports while gaming. All audio enhancements are disabled. Since my headphones do not have a mic, I have also tried disabling front mic line in but nothing has helped.
My Hardware
Motherboard: ASUS ROG Crosshair X870e Hero (Realtek ALC4082)
Headphones: Beyerdynamic DT 700 PRO X
OS: Windows 11 Pro v24H2 Build 26100.2033
MoKiChU
Level 40
@IreuN wrote:
hello, which driver to use with ASUS ROG STRIX B650E-E GAMING WIFI? Currently at Version 6.3.9600.2376
You have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of this thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
My Hardware
Motherboard: ASUS ROG Crosshair x870e Hero (Realtek ALC4082)
You have an ASUS ROG Realtek|Dolby Atmos motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) from the first post of this thread.
Note : If your audio cracking issues persists, follow the tips from the bottom of all my audio drivers threads.
I have installed the correct driver, exactly as described by the instructions. Disabling hibernation did not fix the problem. After searching the Web, I can see there are a lot of other people who are reporting trouble (buzzing, popping, crackling noise) with the Realtek ALC408x chip. As I said, all audio enhancements have been disabled, amplify level has been reduced to Performance, and Default Format has been reduced to 48000Hz 16bits but nothing has improved from the front and rear line out ports. I can literally hear the amount of electricity that my system is using through my headphones. The noise is so intrusive that I cannot use my computer for anything that requires audio.
Here are my Realtek Audio Console settings
Hi, I had the same problem.
There should be a Firmware update for your sound card on the driver page of the motherboard model you are using.
When you install it, the problem should be fixed.
ASUS uses the ALC4080 sound chip on many X670, B650, Z790, Z690 motherboards.
They have released Firmware updates for this sound chip over time to address the sound cracking issue.
https://rog.asus.com/us/motherboards/rog-strix/rog-strix-z790-e-gaming-wifi-model/helpdesk_bios/
For example, there is a Firmware update on the Asus ROG Z790E Gaming Wifi motherboard driver page. This is the latest FW update for ALC4080. It can also be used on other motherboards. Because the sound chip is an independent component from the motherboard. And the FW update will not cause a problem. If you specify the sound chip and model of your motherboard, I can help.
After the FW Update, you should install the latest driver shared by Mokichu according to the instructions.
After this, the sound problem should no longer occur.
Please install the driver according to the instructions.
But be sure to check the FW update on your motherboard's page.
AMD RYZEN 9 7900X3D | ASUS ROG CROSSHAIR X670E HERO | ASUS ROG STRIX LC III 360 ARGB | G.SKILL TridentZ5 NEO RGB 2X24GB 6400Mhz CL32 | ASUS TUF Gaming GeForce RTX™ 4070 Ti SUPER | Asus ROG Strix SCOPE | Asus ROG GLADIUS II CORE | XPG SX8200PRO 2x2TB nVME | XPG SX8100 2x2TB nVME | Corsair RM1000x Shift 80+ Gold | Corsair 5000D Case
Hey. Thanks for replying. From what I understand, the Realtek audio chip for the Crosshair X870e Hero is ALC4082. I have looked at the BIOS & Firmware webpage for the Crosshair X870e Hero but the only available download is the BIOS version 0505 which I have already updated. The Driver & Tools page for the Crosshair X870e Hero only shows the previous USB Audio Realtek driver version 6.3.9600.2393.
Are you saying that the "Audio ALC4080 FW update tool" will fix the crackling problem with the Realtek ALC4082, too? Will there be any hardware conflicts with installing the firmware update tool on an AMD board?
Your motherboard is a newer generation motherboard.
First Step; If your audio codec is ALC4082, you can download and apply the fix patch from a motherboard page that also uses the 4082 codec and has a published firmware.
The critical issue here is which version of the audio codec is and whether the FW has been published.
If the FW has not been published, you will wait for the motherboard manufacturer to publish it.
Second Step; If the sound crackling is happening through the analog output, I suggest you try and check the optical output.
Apart from that, I am leaving the following link shared by a user who had the same or similar problem as you. I suggest you follow the steps in the topic and check if the sound is cracking.
https://www.reddit.com/r/ASUS/comments/sf4tau/fixes_for_realtek_alc4080_sound_problems_on_asus/
The audio firmware update tools are board-specific, I have tried both of the Crosshair X670e Hero and Strix Z790-E Gaming WiFi updaters but neither are compatible with the Crosshair X870e Hero. Maybe I'll check if the S/PDIF performs differently but I'm tired of chasing my tail to solve this.
Thanks for sharing the Reddit link but I am waiting for the X870e Hero ALC4082 firmware update tool to be released. It's infuriating that manufacturers are knowingly selling boards with flawed components. I'm not sure who is more at fault, ASUS or Realtek, but both of them are aware of problems with the ALC4080 and ALC4082 codecs - otherwise there wouldn't be audio firmware update tools, that are digitally signed by Realtek Semiconductor Corp., on the ASUS motherboard downloads list. Evidently this has been an ongoing issue for years and these components are still leaving the factories with the problematic firmware instead of the revised version.
MoKiChU
Level 40
Hi everyone,
For information :
MoKiChU_0-1729619331815.pngSource : https://support.microsoft.com/windows/d5c2cdcd-83a2-4805-abb0-c6888138e456
So, no worries if you upgraded to Windows 11 24H2 from a previous version, but if you plan to do a clean install of Windows 11 24H2, be aware that any AC-3 content will no longer be decoded/played natively, you will need to install an Dolby Digital Plus Decoder addon from the Microsoft Store.
For this purpose, I added an Dolby Digital Plus Decoder addon Microsoft Store shortcut in "Apps" folder of all audio drivers packages.
Drivers packages updated.
