05-29-2020 07:00 AM - last edited a week ago
Hi everyone,
- Realtek USB Audio Drivers (UAD - ASUS ROG Dolby) :
ASUS ROG Dolby Atmos motherboards :
Install/Update Process :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Dolby Access installed /!\
Uninstall them (Start > Settings > Apps) then restart your PC
Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
a-volute | avolute | dax | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button
INSTALL
Launch "Install.cmd" by right-click Run as admin > "Next" > The installer will ask you to restart your PC > "Finish"
Go in "Apps" folder > Install your apps from the Microsoft Store shortcuts
UPDATE
Launch "Update.cmd" by right-click Run as admin > Automatic restart when install is done
Launch Driver Store Explorer > Click on the "Select Old Driver(s)" button > Click on the "Delete Driver(s)" button
Note : Your apps will be updated automatically via the Microsoft Store.
- Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) :
ASUS ROG SS|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS Sound Unbound installed /!\
INSTALL
(You need to install Armoury Crate to install/use the SS drivers/app)
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) :
ASUS ROG SS3|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Sonic Studio/Radar III, DTS Sound Unbound installed /!\
Launch SS3 Cleaner by right-click Run as admin
Press Windows key + X > "Device Manager" > "View" > Check "Show hidden devices" > "Sofware components" category
Uninstall these hidden devices by right-click Uninstall device (if you find them) then restart your PC :
DTS Audio Effects Component | DTS APO4x Service Component
INSTALL
Update your SS3 apps : Sonic Studio III v3.16.24.0 | Sonic Radar III v3.16.24.0
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS PRIME DTSX Ultra) :
ASUS PRIME DTS:X Ultra motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS:X Ultra installed /!\
a-volute | avolute | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button then restart your PC
INSTALL
UPDATE
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements (AMD) : ASUS ROG motherboards with AMD 5xx/6xx/8xx series chipsets with ALC40xx codec.
Hardware requirements (AMD - sTRX4) : ASUS ROG/PRIME motherboards with AMD TRX40 chipset.
Hardware requirements (Intel) : ASUS ROG motherboards with Intel 5xx/6xx/7xx/8xx series chipsets with ALC40xx codec.
Note : In order to know which drivers package to use, match the audio specifications of your motherboard with the apps or ask me.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
If you experience crackling, popping, audio stutter
Disable hibernation (Fast Startup included).
08-04-2024 10:35 PM - edited 08-05-2024 07:59 AM
@MrAgapiGC wrote:
why on yours ??? no idea
Probably because he manually updating/installing Realtek Audio Control (the Realtek HSA SWC Driver gives the installation order to the Microsoft Store for the appropriate version, i.e. Realtek Audio Control v1.51.337.0 with the Realtek USB Audio Drivers v6.4.0.2395 and not the v1.51.339.0).
08-04-2024 11:15 PM
Downgrading to 337 doesn't help
08-04-2024 11:53 PM - edited 08-05-2024 06:41 AM
I did the installation exactly as you described and UI Version 1.51.337.0 is displayed for me and that also came from the MS Store.
08-10-2024 03:13 PM
So what is the fix for this? Am I correct to say these are the drivers for my board: Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) : Z790A WIFI II
08-04-2024 11:50 PM
After cleaning up every driver from the cleanup process and downloading the new driver that installs with the UI made things even worse, now the realteak console says can't connect to RPC service. I'm not seeing it in the driver store explorer either.
So I did something stupid and installed very old drivers from the Asus store and look... magically everything works.
Since this forum is not a github page where once can easily download previous version, I hate to ask, but does anyone have the zip file? Thanks
08-05-2024 12:03 AM
Zip file of what?
Everything is available for download here.
As I understand it, you should uninstall the old driver according to MoKiChU's instructions. He describes everything.
When everything is ready and there are further updates later, you can do the "update" directly, he also describes.
08-05-2024 03:50 AM
hum, actually perhaps i misspoke. i checked the versions and the update process hasn't updated the services etc since March. when i do a clean reinstall (following the procedure) with the current version none of the services are installed at all.
08-05-2024 04:44 AM - edited 08-05-2024 04:44 AM
actually, possibly i've been installing the 'wrong' version this whole time, i've been using SS-DTS, when i just clean installed the current SS3-DTS everything works.
@MoKiChU how do we tell which version we are supposed to use? i have an X670E Crosshair Hero, i'm sure somebody told me it was SS-DTS a while back.
08-05-2024 04:47 AM
You have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of this thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
08-05-2024 05:08 AM
Thanks for the hint, looks like I was installing the wrong version as well. I needed SS3-DTS as well it would seem and now realtek audio control works fine as well as the mic boost feature.
