05-29-2020 07:00 AM - last edited a week ago
Hi everyone,
- Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) :
ASUS ROG Realtek|Dolby Atmos motherboards :
Install/Update Process :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Dolby Access installed /!\
Uninstall them (Start > Settings > Apps) then restart your PC
Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
a-volute | avolute | dax | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button
INSTALL
Launch "Install.cmd" by right-click Run as admin > "Next" > The installer will ask you to restart your PC > "Finish"
Go in "Apps" folder > Install your apps from the Microsoft Store shortcuts
UPDATE
Launch Driver Store Explorer > Click on the "Select Old Driver(s)" button > Click on the "Delete Driver(s)" button
Note : Your apps will be updated automatically via the Microsoft Store.
- Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) :
ASUS ROG SS|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS Sound Unbound installed /!\
INSTALL
(You need to install Armoury Crate to install/use the SS drivers/app)
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) :
ASUS ROG SS3|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Sonic Studio/Radar III, DTS Sound Unbound installed /!\
Launch SS3 Cleaner by right-click Run as admin
Press Windows key + X > "Device Manager" > "View" > Check "Show hidden devices" > "Sofware components" category
Uninstall these hidden devices by right-click Uninstall device (if you find them) then restart your PC :
DTS Audio Effects Component | DTS APO4x Service Component
INSTALL
Update your SS3 apps : Sonic Studio III v3.16.24.0 | Sonic Radar III v3.16.24.0
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS PRIME DTSX Ultra) :
ASUS PRIME DTS:X Ultra motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS:X Ultra installed /!\
a-volute | avolute | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button then restart your PC
INSTALL
UPDATE
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements (AMD) : ASUS ROG motherboards with AMD 5xx/6xx/8xx series chipsets with ALC40xx codec.
Hardware requirements (AMD - sTRX4) : ASUS ROG/PRIME motherboards with AMD TRX40 chipset.
Hardware requirements (Intel) : ASUS ROG motherboards with Intel 5xx/6xx/7xx/8xx series chipsets with ALC40xx codec.
Note : In order to know which drivers package to use, match the audio specifications of your motherboard with the apps or ask me.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
If you experience crackling, popping, audio stutter
Disable hibernation (Fast Startup included).
07-31-2024 07:18 PM
Hello @MoKiChU
Just got the Strix X670E-F GAMING WIFI Motherboard and 9700X CPU, as my 5950X system died.
This motherboard has a weird 'USB' audio system on it, and after installing the Asus drivers from the MB product page, I get popping as Windows starts up, through the speakers. Low, and about 5 or 6 pops while windows is loading before the Welcome screen.
Found a similar situation a few years ago, which you suggested a few things to the User, and then I did the same thing but using the drivers in this thread - however the issue has not gone away.
When W11 first installed, it had Microsoft Drivers and stating it was USB 2.0 Audio etc, and the popping was not present, until I installed the Asus Realtek ones.
Anyway, I uninstalled as you explained in the first post with the various apps, removed the drivers etc, and installed with the new drivers, but the issue is still present.
Any ideas?
Thanks
08-01-2024 09:10 AM - edited 08-02-2024 06:48 AM
Hi everyone,
@ ASUS ROG SS3|DTS Sound Unbound motherboards users : SS3 apps v3.16.24.0 (which is, to date, still not offered by the Microsoft Store which still offers the v3.16.21.0) links have been added to your INSTALL process (offered as offline installer packages).
08-01-2024 09:11 AM
Hi everyone,
- SS3 Extension Driver have been updated for this drivers package :
Drivers : 6.3.9600.2391 WHQL [13/06/2024]
Thread, post & drivers package updated.
08-01-2024 09:44 AM - edited 08-02-2024 09:58 AM
Hi everyone,
@ ASUS ROG SS3|DTS Sound Unbound motherboards users : SSVM is avoided and is no longer installed since this latest update of the SS3 Extension Driver (this was done because SSVM generated too many stability issues according to ASUS and it triggered Vanguard anti-cheat from Riot).
08-01-2024 04:49 PM - edited 08-01-2024 04:52 PM
done. i know we get what we get and thanks as always
RANT MOMENT
Personal speaking and a personal note.... a-volute/Stealseries need to shut down completely. what a trash solution fake sounds. all their personal have to get fire and asus move to the new one, thatis quatrytrilion better.
thanks for the notes and updates.
the entire planet need to follow a game that is a MALWARE root kit, and all need to accommodate their will. RANT OVER..
Thanks boss update install and will a test but i am almost certain i will return to the old one that is better
08-02-2024 10:12 AM - edited 10-13-2024 10:38 PM
Hi everyone,
Thread updated.
08-02-2024 10:36 AM
Hi, @MoKiChU !
Updating Sonic apps now didn't needed. They are installed latest versions from links in Apps drivers folder.
08-02-2024 11:34 AM
Wrong, to date the Microsoft Store still offers the SS3 apps v3.16.21.0 (as previously stated), if you had previously installed the SS3 apps v3.16.24.0 from the offline installer packages that I offer in your INSTALL process, and that the SS3 apps v3.16.24.0 was offered to you by the Microsoft Store following an uninstall-reinstall of the apps, it's that the SS3 apps v3.16.24.0 was in your Microsoft Store installation cache (this also means that you did not follow your CLEANUP process scrupulously because the SS3 apps are cleaned from the Microsoft Store cache by SS3 Cleaner).
