[DRIVERS] Realtek USB Audio (AMD 5xx/6xx/8xx & Intel 5xx/6xx/7xx/8xx)
MoKiChU
Level 40
Hi everyone,
- Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) :
Drivers : 6.4.0.2414 WHQL [24/03/2025]
Dolby Extension Driver : 9.830.414.4 WHQL [29/08/2024]
Dolby HSA SoftwareComponent Driver : 3.30803.830.0 WHQL [17/12/2024]
Download : Link
ASUS ROG Realtek|Dolby Atmos motherboards :
Install/Update Process :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Dolby Access installed /!\
Uninstall them (Start > Settings > Apps) then restart your PC
Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
a-volute | avolute | dax | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button
INSTALL
Launch "Install.cmd" by right-click Run as admin > "Next" > The installer will ask you to restart your PC > "Finish"
Go in "Apps" folder > Install your apps from the Microsoft Store shortcuts
UPDATE
Launch Driver Store Explorer > Click on the "Select Old Driver(s)" button > Click on the "Delete Driver(s)" button
Note : Your apps will be updated automatically via the Microsoft Store.
- Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) :
DTS APO4x Extension Driver : 1.15.1.0 WHQL [22/01/2025]
Download : Link
ASUS ROG SS|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS Sound Unbound installed /!\
INSTALL
(You need to install Armoury Crate to install/use the SS drivers/app)
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) :
SS3 Extension Driver : 1.4.0.0 WHQL [17/04/2023]
SS3 AudioProcessingObject Driver : 3.7.2.0 WHQL [20/06/2024]
Download : Link
ASUS ROG SS3|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Sonic Studio/Radar III, DTS Sound Unbound installed /!\
Launch SS3 Cleaner by right-click Run as admin
Press Windows key + X > "Device Manager" > "View" > Check "Show hidden devices" > "Sofware components" category
Uninstall these hidden devices by right-click Uninstall device (if you find them) then restart your PC :
DTS Audio Effects Component | DTS APO4x Service Component
INSTALL
Update your SS3 apps : Sonic Studio III v3.16.24.0 | Sonic Radar III v3.16.24.0
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS PRIME DTSX Ultra) :
DTS APO4x Service SoftwareComponent Driver : 1.15.11.0 WHQL [12/03/2025]
DTS APO4x Core AudioProcessingObject|SoftwareDevice Driver : 1.15.6.0 WHQL [17/02/2025]
DTSX Ultra HSA SoftwareComponent Driver : 1.11.6.0 WHQL [30/04/2024]
Download : Link
ASUS PRIME DTS:X Ultra motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS:X Ultra installed /!\
a-volute | avolute | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button then restart your PC
INSTALL
UPDATE
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements (AMD) : ASUS ROG motherboards with AMD 5xx/6xx/8xx series chipsets with ALC40xx codec.
Hardware requirements (AMD - sTRX4) : ASUS ROG/PRIME motherboards with AMD TRX40 chipset.
Hardware requirements (Intel) : ASUS ROG motherboards with Intel 5xx/6xx/7xx/8xx series chipsets with ALC40xx codec.
Note : In order to know which drivers package to use, match the audio specifications of your motherboard with the apps or ask me.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
If you experience crackling, popping, audio stutter
Disable hibernation (Fast Startup included).
1,213 REPLIES 1,213
Ataemonus
Level 11
Thank you, Mokichu, awesome as always.
MoKiChU
Level 40
MoKiChU wrote:
Hi everyone,
News ASUS ROG SS3 Apps Updates (Early Access | Offline Installer) :
Sonic Studio III v3.16.23.0 : Link
Sonic Radar III v3.16.23.0 (Optional) : Link
HI mokichu i have questions is this necessary to download? or just stick to current versions.
You can just stick to current versions from Microsoft Store (anyway the new versions will also be available via the Microsoft Store soon).
umiumi223 wrote:
hi. thanks for updating.
but i have occured same issue previous question. like this
is this normal?
Again, there is no issue, these messages just indicates that the driver is already present and installed (no new driver to install).
©ö�ë©.X999;867689 wrote:
hello.
I did all the process from cleaning, installing and updating but still got error. I don't know if I installed the right drivers here ??
I have a Z490 Maximus XII Hero (wifi)
You are on the wrong thread, I answered you in the right thread : https://rog.asus.com/forum/showpost.php?p=867907
Apexing wrote:
Ive done all the steps and installed the drivers for Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) . my mainboard is the Asus ROG STRIX Z690-A GAMING WIFI D4, i followed all the cleanup and install instructions.
However are these driver not supposed to include Enhancements -> Loudness Equalization ? i am not seeing any enhancement tab located in the windows speaker properties
This Enhancements tab is only displayed when you use the Microsoft built-in generic audio drivers. When you use the audio drivers specific to your motherboard, the audio enhancement is configured via your audio apps (Realtek Audio Control/Console, SS3, DTS Sound Unbound), however I would like to point out that you will not find this Loudness Equalization option in them anyway. If you want to have it no matter what, you have no other choice but to follow scrupulously your CLEANUP process in order to switch to Microsoft built-in generic drivers (but you will be unable to use Realtek Audio Control/Console, SS3, DTS Sound Unbound).
hi Mokichu,
i have ROG-STRIX B560-I motherboard.
which package should i install?
thanks,
Yo.
kenshinhimura wrote:
hi Mokichu,
thanks,
Yo.
You have an ASUS ROG SS3|DTS Sound Unbound motherboard, so :
You need Realtek Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of this thread : [DRIVERS] Realtek Audio (Intel 2xx/3xx/4xx/5xx/6xx/7xx & AMD 3xx/4xx/5xx/6xx).
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
MoKiChU wrote:
Thank you Mokichu.
Chrizzy
Having a slight issue!
I´ve got the Z690 Hero board.
Installed the Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS MB) drivers
and Realtek Control panel via MStore but when I open it I get a message saying: Can not connect to RPC service.
What to do? 😛
What to do? 😛
hi try reset or restart at app settings on realtek audio console
I finally managed to fix it. Manually wiped all Realtek related stuff in registry etc.
And reinstalled the drivers via the bat file + manually installed them as well.
