[DRIVERS] Realtek USB Audio (AMD 5xx/6xx/8xx & Intel 5xx/6xx/7xx/8xx)
MoKiChU
Level 40
Hi everyone,
- Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) :
Drivers : 6.4.0.2414 WHQL [24/03/2025]
Dolby Extension Driver : 9.830.414.4 WHQL [29/08/2024]
Dolby HSA SoftwareComponent Driver : 3.30803.830.0 WHQL [17/12/2024]
Download : Link
ASUS ROG Realtek|Dolby Atmos motherboards :
Install/Update Process :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Dolby Access installed /!\
Uninstall them (Start > Settings > Apps) then restart your PC
Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
a-volute | avolute | dax | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button
INSTALL
Launch "Install.cmd" by right-click Run as admin > "Next" > The installer will ask you to restart your PC > "Finish"
Go in "Apps" folder > Install your apps from the Microsoft Store shortcuts
UPDATE
Launch Driver Store Explorer > Click on the "Select Old Driver(s)" button > Click on the "Delete Driver(s)" button
Note : Your apps will be updated automatically via the Microsoft Store.
- Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) :
DTS APO4x Extension Driver : 1.15.1.0 WHQL [22/01/2025]
Download : Link
ASUS ROG SS|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS Sound Unbound installed /!\
INSTALL
(You need to install Armoury Crate to install/use the SS drivers/app)
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) :
SS3 Extension Driver : 1.4.0.0 WHQL [17/04/2023]
SS3 AudioProcessingObject Driver : 3.7.2.0 WHQL [20/06/2024]
Download : Link
ASUS ROG SS3|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Sonic Studio/Radar III, DTS Sound Unbound installed /!\
Launch SS3 Cleaner by right-click Run as admin
Press Windows key + X > "Device Manager" > "View" > Check "Show hidden devices" > "Sofware components" category
Uninstall these hidden devices by right-click Uninstall device (if you find them) then restart your PC :
DTS Audio Effects Component | DTS APO4x Service Component
INSTALL
Update your SS3 apps : Sonic Studio III v3.16.24.0 | Sonic Radar III v3.16.24.0
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS PRIME DTSX Ultra) :
DTS APO4x Service SoftwareComponent Driver : 1.15.12.0 WHQL [30/04/2025]
DTS APO4x Core AudioProcessingObject|SoftwareDevice Driver : 1.15.10.0 WHQL [28/05/2025]
DTSX Ultra HSA SoftwareComponent Driver : 1.11.6.0 WHQL [30/04/2024]
Download : Link
ASUS PRIME DTS:X Ultra motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS:X Ultra installed /!\
a-volute | avolute | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button then restart your PC
INSTALL
UPDATE
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements (AMD) : ASUS ROG motherboards with AMD 5xx/6xx/8xx series chipsets with ALC40xx codec.
Hardware requirements (AMD - sTRX4) : ASUS ROG/PRIME motherboards with AMD TRX40 chipset.
Hardware requirements (Intel) : ASUS ROG motherboards with Intel 5xx/6xx/7xx/8xx series chipsets with ALC40xx codec.
Note : In order to know which drivers package to use, match the audio specifications of your motherboard with the apps or ask me.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
If you experience crackling, popping, audio stutter
Disable hibernation (Fast Startup included).
1,234 REPLIES 1,234
kimohw
When trying to launch sonic studio 3.
I am using Strix B850-A and used the SS3 driver
You tried to install an incorrect drivers package for your motherboard.
You have an ASUS ROG Realtek|Dolby Atmos motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) from the first post of this thread.
Follow scrupulously the CLEANUP process then the INSTALL process from your ASUS ROG Realtek|Dolby Atmos motherboards category, for the next drivers packages that I would release, you will can directly follow the UPDATE process from your ASUS ROG Realtek|Dolby Atmos motherboards category.
Reman_J_Rahman
Hello Bro
I have this Issue in Asus Rog Strix Z790-E Gaming WIFI II  2 | How Can I Fix That ??
I wanna to Use this Software
Screenshot 2025-06-10 232756.pngScreenshot 2025-06-10 232848.pngScreenshot 2025-06-10 232911.png
You have an ASUS ROG SS|DTS Sound Unbound motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) from the first post of this thread.
Follow scrupulously the CLEANUP process then the INSTALL process from your ASUS ROG SS|DTS Sound Unbound motherboards category, for the next drivers packages that I would release, you will can directly follow the UPDATE process from your ASUS ROG SS|DTS Sound Unbound motherboards category.
MoKiChU
Level 40
Hi everyone,
- DTS APO4x Service SoftwareComponent & Core AudioProcessingObject|SoftwareDevice Drivers have been updated for this drivers package :
Thread, post & drivers package updated.
ScoobyRob1986
Hi there I have a new build with a ROG STRIX Z790-F GAMING WIFI II and I'm having issues with very low mic input what drivers do I need I see the motherboard has ROG SupremeFX 5.1 Surround Sound High Definition Audio but want to make sure my drivers are on the latest I appreciate all your time and help many thanks
CODEC ALC4080*
Thank you for this I have the latest drivers installed and the microphone input level is still very low even with a +30 boost applied I shall order a USB sound adapter to test further as audio from mic is absolutely fine via Xbox controller input / output thank you for your time and help @MoKiChU
DyNo85
Hello, I have a ROG STRIX Z790-E GAMING WIFI motherboard (first generation). Which audio driver should I install ?
You have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of this thread.
