[DRIVERS] Realtek USB Audio (AMD 5xx/6xx/8xx & Intel 5xx/6xx/7xx/8xx)
MoKiChU
Level 40
Hi everyone,
- Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) :
Drivers : 6.4.0.2426 WHQL [06/11/2025] | Download : Link
Dolby Extension Driver : 10.1022.825.39 WHQL [21/10/2025]
Dolby HSA SoftwareComponent Driver : 3.30803.830.0 WHQL [17/12/2024]
ASUS ROG Realtek|Dolby Atmos motherboards :
Install/Update Process :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Dolby Access installed /!\
Uninstall them (Start > Settings > Apps) then restart your PC
Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
a-volute | avolute | dax | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button
INSTALL
Launch "Install.cmd" by right-click Run as admin > "Next" > The installer will ask you to restart your PC > "Finish"
Go in "Apps" folder > Install your apps from the Microsoft Store shortcuts
UPDATE
Launch Driver Store Explorer > Click on the "Select Old Driver(s)" button > Click on the "Delete Driver(s)" button
Note : Your apps will be updated automatically via the Microsoft Store.
- Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) :
DTS APO4x Extension Driver : 1.15.3.0 WHQL [12/10/2025]
ASUS ROG SS|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS Sound Unbound installed /!\
INSTALL
(You need to install Armoury Crate to install/use the SS drivers/app)
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) :
SS3 Extension Driver : 1.4.0.0 WHQL [17/04/2023]
SS3 AudioProcessingObject Driver : 3.7.2.0 WHQL [20/06/2024]
ASUS ROG SS3|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Sonic Studio/Radar III, DTS Sound Unbound installed /!\
Launch SS3 Cleaner by right-click Run as admin
Press Windows key + X > "Device Manager" > "View" > Check "Show hidden devices" > "Sofware components" category
Uninstall these hidden devices by right-click Uninstall device (if you find them) then restart your PC :
DTS Audio Effects Component | DTS APO4x Service Component
INSTALL
Update your SS3 apps : Sonic Studio III v3.16.24.0 | Sonic Radar III v3.16.24.0
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS PRIME DTSX Ultra) :
DTS APO4x Service SoftwareComponent Driver : 1.15.18.0 WHQL [28/10/2025]
DTS APO4x Core AudioProcessingObject|SoftwareDevice Driver : 1.15.15.0 WHQL [13/10/2025]
DTSX Ultra HSA SoftwareComponent Driver : 1.11.7.0 WHQL [22/09/2025]
ASUS PRIME DTS:X Ultra motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS:X Ultra installed /!\
a-volute | avolute | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button then restart your PC
INSTALL
UPDATE
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements (AMD) : ASUS ROG motherboards with AMD 5xx/6xx/8xx series chipsets with ALC40xx codec.
Hardware requirements (AMD - sTRX4) : ASUS ROG/PRIME motherboards with AMD TRX40 chipset.
Hardware requirements (Intel) : ASUS ROG motherboards with Intel 5xx/6xx/7xx/8xx series chipsets with ALC40xx codec.
Note : In order to know which drivers package to use, match the audio specifications of your motherboard with the apps or ask me.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
If you experience crackling, popping, audio stutter
Disable hibernation (Fast Startup included).
1,296 REPLIES 1,296
Many thanks for your information, however I have a question, I put back "Realtek Audio Driver V6.3.9600.2333 For Windows 10/11 64-bit." to have my Sonic studio 3 software working and I'm happy because the new drivers from 2024/09/24 were bad... Asus re-released drivers on 2025/03/11 are those reliable or do you advise me to stay on my old version? 🙂
chadmander
hi guys somebody knwos where do i get this  old package? seems like this ones fix all the problems with my 5.1
13th Gen Intel(R) Core(TM) i5-13400 2.50 GHz ,board ROG Maximus Z790 Hero Corsair Vengeance 32 gb ddr5, 3 tb x 3 ssd, GeForce RTX 3050 (8 GB),Thermalright Phantom Spirit 120SE
MoKiChU
Level 40
Hi everyone,
- DTS APO4x Extension Driver have been updated for these drivers packages :
Drivers : 6.4.0.2406 WHQL [27/11/2024]
Thread, post & drivers packages updated.
Hi MoKiChU,
which is the right audio driver for this motherboard:
ROG CROSSHAIR X870E HERO
Thanks in advance.
74lobster
opare00
it worked I think! can't celebrate too early!
cheers
chadmander
where is the speaker configuration on this dirvers packages? installed but i cant find the speaker config
luisnadal
Hi, i want use the Sonic Studio 3 with my rog x870e i can used if the motherboard say its for dolby atmos?. thx
74lobster
Hi MoKiChU,
Thanks in advance.
74lobster
MoKiChU
Level 40
@74lobster wrote:
Hi MoKiChU,
Thanks in advance.
You have an ASUS ROG Realtek|Dolby Atmos motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) from the first post of this thread.
You cannot choose a drivers package type, each drivers package type is dedicated to each motherboards type.
Thanks a lot Hi MoKiChU !
74lobster
