05-29-2020 07:00 AM - last edited 2 weeks ago
Hi everyone,
- Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) :
ASUS ROG Realtek|Dolby Atmos motherboards :
Install/Update Process :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Dolby Access installed /!\
Uninstall them (Start > Settings > Apps) then restart your PC
Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
a-volute | avolute | dax | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button
INSTALL
Launch "Install.cmd" by right-click Run as admin > "Next" > The installer will ask you to restart your PC > "Finish"
Go in "Apps" folder > Install your apps from the Microsoft Store shortcuts
UPDATE
Launch Driver Store Explorer > Click on the "Select Old Driver(s)" button > Click on the "Delete Driver(s)" button
Note : Your apps will be updated automatically via the Microsoft Store.
- Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) :
ASUS ROG SS|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS Sound Unbound installed /!\
INSTALL
(You need to install Armoury Crate to install/use the SS drivers/app)
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) :
ASUS ROG SS3|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Sonic Studio/Radar III, DTS Sound Unbound installed /!\
Launch SS3 Cleaner by right-click Run as admin
Press Windows key + X > "Device Manager" > "View" > Check "Show hidden devices" > "Sofware components" category
Uninstall these hidden devices by right-click Uninstall device (if you find them) then restart your PC :
DTS Audio Effects Component | DTS APO4x Service Component
INSTALL
Update your SS3 apps : Sonic Studio III v3.16.24.0 | Sonic Radar III v3.16.24.0
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS PRIME DTSX Ultra) :
ASUS PRIME DTS:X Ultra motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS:X Ultra installed /!\
a-volute | avolute | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button then restart your PC
INSTALL
UPDATE
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements (AMD) : ASUS ROG motherboards with AMD 5xx/6xx/8xx series chipsets with ALC40xx codec.
Hardware requirements (AMD - sTRX4) : ASUS ROG/PRIME motherboards with AMD TRX40 chipset.
Hardware requirements (Intel) : ASUS ROG motherboards with Intel 5xx/6xx/7xx/8xx series chipsets with ALC40xx codec.
Note : In order to know which drivers package to use, match the audio specifications of your motherboard with the apps or ask me.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
If you experience crackling, popping, audio stutter
Disable hibernation (Fast Startup included).
02-23-2025 10:16 PM
Hello, which is the driver for X670E Hero? There are many links, I couldn't figure it out.
02-23-2025 10:47 PM
You have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of this thread.
02-24-2025 07:24 AM
I have the ROG STRIX Z790-E GAMING WIFI, which drivers would I use?
My best guess from reading the comments would be: ASUS ROG SS3|DTS Sound Unbound motherboard with ALC40xx codec
02-24-2025 07:28 AM
It tells you right in the asus driver page
ss3 and dtss
02-24-2025 07:36 AM
Thanks! another question, what is special about these drivers, I'm trying to use them since the ones in the support page for my motherboard wont install properly and the audio is very bad. I am at work now so I can't try these but hopefully they fix my issue
02-24-2025 08:48 AM
nothing special. They are just more true to the actual newest versions than the mb pages. If you experience issues, try a driver from your motherboard page. They should fit your motherboard though.
Remember to follow the cleanup process strictly. The realtek drivers are notoriously known for doing weird stuff.
Try to disable any audio enhancements in the windows sound property of your output.
Remember that this is not a support thread, and many people are signed up to these threads for driver related updates, not every time Joe Pascal needs a driver for his mobo 😉 ❤️ no hate. Mokichu is not a support assistant though very very helpful, but please dont default to this solution, he gets overloaded with such requests, many people get a notification and mokichu gets zero payment for his efforts.
The rest of the forum is more than capable of helping you out with specific problems in most cases. The least we can do is to try ourselves before we send questions his way 🙂 !
Cheers over and out !
02-24-2025 05:12 PM
Have a strix x870e-e. Which audio driver do I install? The Realtek audio
Realtek Audio Drivers (UAD - ASUS ROG RTK-Dolby) :
and Realtek audio usb
Strix X870e-e / AMD 9800x3d / Gskill 32gb 6000 / Crucial T705 / ASUS Prime 9070 XT / Lian Li 011 compact / Lian Li Hydroshift AIO / Lian Li Platinum 1300 psu / Windows 11 24h2
02-24-2025 07:52 PM
You have an ASUS ROG Realtek|Dolby Atmos motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) from the first post of this thread.
02-24-2025 09:13 PM
Drivers won't install after following every step, it asks me to restart pc, but when I boot back up, no drivers installed. I know it is not a support thread, but I don't know where to go. I have Strix Z790-E Wifi
02-24-2025 09:27 PM
GUYS SORRY I MADE IT WORK. I had to force the drivers folder through device manager. IT FINALLY WORKED.
