05-29-2020 07:00 AM - last edited yesterday
Hi everyone,
- Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) :
ASUS ROG Realtek|Dolby Atmos motherboards :
Install/Update Process :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Dolby Access installed /!\
Uninstall them (Start > Settings > Apps) then restart your PC
Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
a-volute | avolute | dax | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button
INSTALL
Launch "Install.cmd" by right-click Run as admin > "Next" > The installer will ask you to restart your PC > "Finish"
Go in "Apps" folder > Install your apps from the Microsoft Store shortcuts
UPDATE
Launch Driver Store Explorer > Click on the "Select Old Driver(s)" button > Click on the "Delete Driver(s)" button
Note : Your apps will be updated automatically via the Microsoft Store.
- Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) :
ASUS ROG SS|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS Sound Unbound installed /!\
INSTALL
(You need to install Armoury Crate to install/use the SS drivers/app)
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) :
ASUS ROG SS3|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Sonic Studio/Radar III, DTS Sound Unbound installed /!\
Launch SS3 Cleaner by right-click Run as admin
Press Windows key + X > "Device Manager" > "View" > Check "Show hidden devices" > "Sofware components" category
Uninstall these hidden devices by right-click Uninstall device (if you find them) then restart your PC :
DTS Audio Effects Component | DTS APO4x Service Component
INSTALL
Update your SS3 apps : Sonic Studio III v3.16.24.0 | Sonic Radar III v3.16.24.0
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS PRIME DTSX Ultra) :
ASUS PRIME DTS:X Ultra motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS:X Ultra installed /!\
a-volute | avolute | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button then restart your PC
INSTALL
UPDATE
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements (AMD) : ASUS ROG motherboards with AMD 5xx/6xx/8xx series chipsets with ALC40xx codec.
Hardware requirements (AMD - sTRX4) : ASUS ROG/PRIME motherboards with AMD TRX40 chipset.
Hardware requirements (Intel) : ASUS ROG motherboards with Intel 5xx/6xx/7xx/8xx series chipsets with ALC40xx codec.
Note : In order to know which drivers package to use, match the audio specifications of your motherboard with the apps or ask me.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
If you experience crackling, popping, audio stutter
Disable hibernation (Fast Startup included).
11-20-2024 06:18 AM - edited 11-20-2024 06:20 AM
Hi 😊
What are the best drivers for an Asus X870F Gaming?
Before this board I had an Asus B650E E Gaming and I was using this version of drivers:
DRV_Audio_RTK_USB_SZ_W11_64_V6396002333_20220815R
And it had a lot of output power in the headphones, but with the drivers on the Asus page for the X870F it sounds much lower. 😞
11-20-2024 09:14 AM
HI All, I am currently moving platform and going to get a B650E-F Gaming board hopefully by next week. Pevios board was the B550-A Gaming. If i check it owuld be this driver?
Also i see on the support site it has a firmware update for the Audio. Why does some of the Asus boards have different revision firmware updates for the ALC4080. Do i update to the one on the B650E-F page or hunt for the latest one?
11-20-2024 09:50 AM - edited 02-07-2025 08:50 AM
@paul7913538 wrote:
Hello, I have installed it according to the process and confirmed the cleanup, but the Can not connect to RPC service&NOPKEY error still appears. Is there any solution?
If your "Can not connect to RPC service" issue persists :
If your other install issue persist, please refer to these 2 posts (the first then the second if necessary) to troubleshoot :
@CombinE54 wrote:
Hi, MoKiChU!
I'm unable to download the Realtek application by using your "AUDIO_Realtek_Audio_Control_UAD" link - pressing the Install button does nothing for some reason.
x870e Hero, clean Windows 11 24h2 install here, followed your Install guide.
Could you please share if you know what might be wrong?
The 3 services required are up and running.Thanks in advance!
You have an ASUS ROG Realtek|Dolby Atmos motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) from the first post of this thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
You will have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC40xx codec, so :
You will need Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of this thread.
Just use the last firmware from your motherboard support page, you can check by yourself which firmware version you currently use by looking at the 4 last characters of your Realtek USB Audio device hardware id : Device Manager > Sound, video and game controllers > Right click on your Realtek USB Audio device > Properties > Details tab > Hardware Ids : ...&REV_xxxx).
11-20-2024 10:48 AM
Thanks @MoKiChU
Been great dealing with you on the other channel. Always a legend. Good to know about the firmware being updated by the drivers... Looking forward to moving to the AM5 platform now.
11-24-2024 08:14 AM - edited 12-01-2024 01:39 AM
@rckrz6 wrote:
Hello, I am assuming the x870e-e strix uses the RTK-Dolby drivers? Is this correct?
Correct.
@radosuaf wrote:
Where can I find firmware updates for ALC4080? ASUS tends not to publish them on all motherboards support pages although firmware seems to be motherboard agnostic...
Already answered : https://rog-forum.asus.com/t5/downloads-for-motherboards/drivers-realtek-usb-audio-amd-5xx-6xx-8xx-a...
11-24-2024 08:27 AM
Thanks, quick and helpful, as always :).
11-27-2024 03:30 AM
Hi
I just bought Asus ROG X870E Hero motherboard, and install from the Asus Hub. But the Realtek Audio Console can not start, always throwing error can not connect to RPC service. Through search in the web i found this thread and try installing the driver in here by following the guide, but the Realtek Audio Console still can not start. Anyone can help? Thanks
