05-29-2020 07:00 AM - edited 11-12-2024 12:05 AM
Hi everyone,
- Realtek USB Audio Drivers (UAD - ASUS ROG RTK-Dolby) :
ASUS ROG Realtek|Dolby Atmos motherboards :
Install/Update Process :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Dolby Access installed /!\
Uninstall them (Start > Settings > Apps) then restart your PC
Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
a-volute | avolute | dax | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button
INSTALL
Launch "Install.cmd" by right-click Run as admin > "Next" > The installer will ask you to restart your PC > "Finish"
Go in "Apps" folder > Install your apps from the Microsoft Store shortcuts
UPDATE
Launch "Update.cmd" by right-click Run as admin > Restart your PC when the command prompt window disappears
Launch Driver Store Explorer > Click on the "Select Old Driver(s)" button > Click on the "Delete Driver(s)" button
Note : Your apps will be updated automatically via the Microsoft Store.
- Realtek USB Audio Drivers (UAD - ASUS ROG SS-DTS) :
ASUS ROG SS|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS Sound Unbound installed /!\
INSTALL
(You need to install Armoury Crate to install/use the SS drivers/app)
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) :
ASUS ROG SS3|DTS Sound Unbound motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, Sonic Studio/Radar III, DTS Sound Unbound installed /!\
Launch SS3 Cleaner by right-click Run as admin
Press Windows key + X > "Device Manager" > "View" > Check "Show hidden devices" > "Sofware components" category
Uninstall these hidden devices by right-click Uninstall device (if you find them) then restart your PC :
DTS Audio Effects Component | DTS APO4x Service Component
INSTALL
Update your SS3 apps : Sonic Studio III v3.16.24.0 | Sonic Radar III v3.16.24.0
UPDATE
- Realtek USB Audio Drivers (UAD - ASUS PRIME DTSX Ultra) :
ASUS PRIME DTS:X Ultra motherboards :
CLEANUP
/!\ If you already had Realtek USB Audio Driver, Realtek Audio Control/Console, DTS:X Ultra installed /!\
a-volute | avolute | dts | extrtxusb | hdx | realtek | rtdusbad
Check the box "Force Deletion" then click on the "Delete Driver(s)" button then restart your PC
INSTALL
UPDATE
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements (AMD) : ASUS ROG motherboards with AMD 5xx/6xx/8xx series chipsets with ALC40xx codec.
Hardware requirements (AMD - sTRX4) : ASUS ROG/PRIME motherboards with AMD TRX40 chipset.
Hardware requirements (Intel) : ASUS ROG motherboards with Intel 5xx/6xx/7xx/8xx series chipsets with ALC40xx codec.
Note : In order to know which drivers package to use, match the audio specifications of your motherboard with the apps or ask me.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
If you experience crackling, popping, audio stutter
Disable hibernation (Fast Startup included).
11-04-2024 11:29 AM
Which driver do I use on a ROG Zenith 2 Extreme?
11-04-2024 12:28 PM - edited 11-05-2024 10:04 PM
You have an ASUS ROG SS3|DTS Sound Unbound motherboard with AMD TRX40 chipset, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of this thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
11-05-2024 02:24 AM
Hi everyone,
- DTS APO4x Service SoftwareComponent & Core AudioProcessingObject|SoftwareDevice Drivers have been updated for this drivers package :
Drivers : 6.4.0.2400 WHQL [26/09/2024]
Thread, post & drivers package updated.
11-12-2024 12:06 AM
Hi everyone,
Thread updated.
11-12-2024 05:27 PM
Hello, I have a ROG B650-A. Which driver should I install?
By the way, have you ever encountered a yellow exclamation mark on a USB audio device? I have tried updating the driver, but there is no solution.
11-12-2024 09:35 PM
You have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC40xx codec, so :
11-12-2024 09:40 PM
Hello, I have installed it according to the process and confirmed the cleanup, but the Can not connect to RPC service&NOPKEY error still appears. Is there any solution?
11-12-2024 10:37 PM
11-12-2024 10:56 PM
I've tried this too, but it doesn't seem to be a solution.
11-12-2024 11:25 PM
Hello, I have tried this too, but the situation is still the same. The strange thing is that Realtek confirmed that it is version 6.4.0.2402. Is there any other solution?
