05-10-2020 02:39 PM - last edited Friday
Hi everyone,
- Realtek Ethernet Drivers (Drivers Only) :
Install/Update Process :
- Press Windows key + X > Device Manager > Right-click on your Realtek Ethernet device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (ETHERNET_Realtek_v...) > Next
- Realtek WiFi Drivers (Drivers Only) :
- Press Windows key + X > Device Manager > Right-click on your Realtek WiFi device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (WiFi_Realtek_v...) > Next
- Realtek Bluetooth Drivers (Drivers Only) :
- Press Windows key + X > Device Manager > Right-click on your Realtek Bluetooth device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (BT_Realtek_v...) > Next
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Realtek Ethernet/WiFi/Bluetooth controller.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
11-07-2024 04:10 AM
Hi everyone,
Thread updated.
11-08-2024 11:27 AM
Hi everyone,
Thread updated.
3 weeks ago
Hi everyone,
@ Realtek Ethernet controllers users :
As reminder :
- If you are using Windows 10 : There is no choice to make, you must use Windows 10/NDIS Drivers (10.xx.xxxx.xxxx).
- If you are using Windows 11 : I recommend that you try Windows 11/NetAdapterCx Drivers (11xx.xx.xxxx.xxxx) type first and switch to Windows 10/NDIS Drivers (10.xx.xxxx.xxxx) type only if you have an issue :
2 weeks ago
I needed drivers for the 8852BE Bluetooth and Wifi because the ones provided by the manufacturer were so outdated bluetooth didn't even work and I have no idea what cards are whitelisted (tried 2 others, didn't even show up).
2 weeks ago
Hi everyone,
Thread updated.
2 weeks ago
Hi everyone,
Thread updated.
a week ago
Hi everyone,
Thread updated.
Friday
Hi everyone,
Thread updated.
