[DRIVERS] Realtek Ethernet/WiFi/Bluetooth
MoKiChU
Level 40
Hi everyone,
- Realtek Ethernet Drivers (Drivers Only) :
Drivers - Windows 11 : 11xx.16.1123.2023 WHQL [23/11/2023]
Drivers - Windows 10 : 10.69.1121.2023 WHQL [21/11/2023]
Download - Windows 11 : Link
Download - Windows 10 : Link
Install/Update Process :
- Press Windows key + X > Device Manager > Right-click on your Realtek Ethernet device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (ETHERNET_Realtek_v...) > Next
- Realtek WiFi Drivers (Drivers Only) :
Drivers - 8852CE : 6001.16.154.0 WHQL [14/03/2024]
Drivers - 8852BE : 6001.15.150.0 WHQL [23/01/2024]
Drivers - 8851BE - Windows 11 : 6101.19.117.0 WHQL [30/01/2024]
Drivers - 8851BE - Windows 10 : 6001.19.116.100 WHQL [17/01/2024]
Drivers - 8723DE/8821CE/8822xE : 2024.10.139.3 WHQL [15/01/2024]
Drivers - 81xxEE/8723BE/88xxAE : 2024.0.4.209 WHQL [15/03/2021]
Download - 8852CE : Link
Download - 8852BE : Link
Download - 8851BE - Windows 11 : Link
Download - 8851BE - Windows 10 : Link
Download - 8723DE/8821CE/8822xE : Link
Download - 81xxEE/8723BE/88xxAE : Link
- Press Windows key + X > Device Manager > Right-click on your Realtek WiFi device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (WiFi_Realtek_v...) > Next
- Realtek Bluetooth Drivers (Drivers Only) :
Drivers - 8852CE : 1.10.1066.3000 WHQL [10/12/2023]
Drivers - 8852BE : 1.10.1061.3005 WHQL [08/11/2023]
Drivers - 8851BE : 2.10.1061.3009 WHQL [19/10/2023]
Drivers - 8723DE/8821CE/8822xE : 1.10.1061.3000 WHQL [21/04/2023]
Drivers - 81xxEE/8723BE/88xxAE : 1.7.1019.3002 WHQL [02/07/2019]
Download - 8851BE : Link
- Press Windows key + X > Device Manager > Right-click on your Realtek Bluetooth device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (BT_Realtek_v...) > Next
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Realtek Ethernet/WiFi/Bluetooth controller.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
150 REPLIES 150
MoKiChU
Level 40
Hi everyone,
Drivers - Windows 11 : 11xx.13.424.2023 WHQL [24/04/2023]
Thread updated.
MoKiChU
Level 40
Hi everyone,
Drivers - Windows 10 : 10.65.421.2023 WHQL [21/04/2023]
Thread updated.
Thilxn1248
USB\VID_0BDA&PID_8771&REV_0200
this is the hardware ID which should i install
bluetooth driver
Please stop spamming my threads with same questions. You already asked that in my index thread, and i already answered you : https://rog-forum.asus.com/t5/hardware-build-advice/index-all-my-firmware-drivers-software-threads/m....
@MoKiChU wrote:
Your motherboard (I have the same motherboard) don't have Bluetooth controller built-in and the HWID USB\VID_0BDA&PID_8771 corresponds to a Realtek Bluetooth device.
So if you added BT via BT USB adapter, please refer to your product support page to download/use the appropriate drivers for your product.
@ Everyone
: I remind to everyone that my field is the ASUS motherboards (DIY PC) and that all my threads are AIMed for ASUS motherboards only and not AIMed for ASUS notebooks/laptops/AiO or any ASUS devices like ASUS WiFi/BT USB adapters. So if you don't have ASUS motherboards my threads are not for you, please refer to your product support page to download/use the appropriate drivers for your product.
So I'm telling you one last time more clearly, you will not find the appropriate driver for the Realtek Bluetooth device with the HWID USB\VID_0BDA&PID_8771 in this thread because this HWID does not correspond to an ASUS motherboards Realtek Bluetooth built-in controller.
MoKiChU
Level 40
Hi everyone,
Drivers - 8852BE : 6001.15.141.0 WHQL [18/04/2023]
Thread updated.
MoKiChU
Level 40
Hi everyone,
Drivers - 8723DE/8821CE/8822xE : 1.10.1060.3001 WHQL [03/03/2023]
Thread updated.
MoKiChU
Level 40
Hi everyone,
Drivers - 8852BE : 1.9.1051.3013 WHQL [12/05/2023]
Thread updated.
MoKiChU
Level 40
Hi everyone,
Drivers - 8852BE : 6001.15.143.0 WHQL [06/06/2023]
Thread updated.
MoKiChU
Level 40
Hi everyone,
Drivers - Windows 11 : 11xx.14.613.2023 WHQL [13/06/2023]
Thread updated.
