[DRIVERS] Realtek Ethernet/WiFi/Bluetooth
MoKiChU
Level 40
Hi everyone,
- Realtek Ethernet Drivers (Drivers Only) :
Drivers - Windows 11 : 11xx.15.717.2023 WHQL [17/07/2023]
Drivers - Windows 10 : 10.68.815.2023 WHQL [15/08/2023]
Download - Windows 11 : Link
Download - Windows 10 : Link
Install/Update Process :
- Press Windows key + X > Device Manager > Right-click on your Realtek Ethernet device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (ETHERNET_Realtek_v...) > Next
- Realtek WiFi Drivers (Drivers Only) :
Drivers - 8852BE : 6001.15.146.1 WHQL [21/09/2023]
Drivers - 8723DE/8821CE/8822xE : 2024.10.139.1 WHQL [28/09/2023]
Drivers - 81xxEE/8723BE/88xxAE : 2024.0.4.209 WHQL [15/03/2021]
Download - 8852BE : Link
Download - 8723DE/8821CE/8822xE : Link
Download - 81xxEE/8723BE/88xxAE : Link
- Press Windows key + X > Device Manager > Right-click on your Realtek WiFi device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (WiFi_Realtek_v...) > Next
- Realtek Bluetooth Drivers (Drivers Only) :
Drivers - 8852BE : 1.10.1061.3004 WHQL [22/09/2023]
Drivers - 8723DE/8821CE/8822xE : 1.10.1061.3000 WHQL [21/04/2023]
Drivers - 81xxEE/8723BE/88xxAE : 1.7.1019.3002 WHQL [02/07/2019]
- Press Windows key + X > Device Manager > Right-click on your Realtek Bluetooth device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (BT_Realtek_v...) > Next
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Realtek Ethernet/WiFi/Bluetooth controller.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
135 REPLIES 135
piratino
Amazing! Thank you!!!
piratino
Updated the WiFi driver succesfully, but the BT ones do not update.
Here is what I get in RAPR:
85305
Tried to force update manually but Windows says I have latest driver installed. Any clue?
I updated the thread (ASUS hardware ID not supported by the 1.8.xxxx.xxxx branch), you can try again.
MoKiChU wrote:
I forced the driver 1.8 just before seeing this post.
Did it manually selecting the v4.2 as my motherboard specs. Installed it and seemed to work, but as it is tricky (and immagine will NOT bring that much of improvements -- in case YES, please tell us about it), I switched to the 1.7 you just posted. Every thing perfect!
Need to say that the "The operation completed successfully" came up after a while, and not immediately, so it is metter to wait a bit before thinking it was not installed.
I updated the thread again (with 1.8.xxxx.xxxx branch for ASUS hardware ID), you can try again a last time.
MoKiChU
Level 40
Hi everyone,
Drivers : 1.8.1025.3000 WHQL [27/03/2020]
Thread updated.
MoKiChU wrote:
Hi everyone,
Download : Link
Thread updated.
It works! Super thanks!!
MoKiChU
Level 40
Hi everyone,
Drivers : 10.42.526.2020 WHQL [26/05/2020]
Thread updated.
MoKiChU
Level 40
Hi everyone,
Drivers : 1.8.1026.3000 WHQL [13/04/2020]
Thread updated.
