[DRIVERS] Intel Ethernet/WiFi/Bluetooth
MoKiChU
Level 40
Hi everyone,
- Intel Ethernet Drivers (Drivers Only) :
Drivers - I225/I226 - Windows 11 : 2.1.4.3 WHQL [20/02/2024]
Drivers - I225/I226 - Windows 10 : 1.1.4.43 WHQL [15/02/2024]
Drivers - I217/I218/I219 - Windows 10/11 : 12.19.2.62 WHQL [18/07/2024]
Drivers - I210/I211 - Windows 11 : 14.1.5.0 WHQL [20/05/2024]
Drivers - I210/I211 - Windows 10 : 14.0.5.0 WHQL [23/09/2024]
Drivers - 82579 - Windows 10 : 12.15.31.4 WHQL [25/07/2016]
Download - I225/I226 - Windows 11 : Link
Download - I225/I226 - Windows 10 : Link
Download - I217/I218/I219 - Windows 10/11 : Link
Download - I210/I211 - Windows 11 : Link
Download - I210/I211 - Windows 10 : Link
Download - 82579 - Windows 10 : Link
Install/Update Process :
- Press Windows key + X > Device Manager > Right-click on your Intel Ethernet device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (ETHERNET_Intel_v...) > Next
- Intel WiFi Drivers (Drivers Only) :
Drivers - 9xxx/AXxxx/BExxx : 23.100.0.4 WHQL [11/11/2024]
Drivers - 8xxx : 22.200.2.1 WHQL [09/03/2023]
Drivers - 3165/3168/7265D : 23.40.1.1 WHQL [20/03/2024]
Drivers - 3160/7260/7265C : 18.33.17.1 WHQL [29/04/2019]
Download - 9xxx/AXxxx/BExxx : Link
Download - 8xxx : Link
Download - 3165/3168/7265D : Link
Download - 3160/7260/7265C : Link
- Press Windows key + X > Device Manager > Right-click on your Intel WiFi device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (WiFi_Intel_v...) > Next
- Intel Bluetooth Drivers (Drivers Only) :
Drivers - 9xxx/AXxxx/BExxx : 23.100.0.4 WHQL [12/11/2024]
Drivers - 8xxx : 22.200.0.2 WHQL [15/12/2022]
Drivers - 3165/3168/7265D : 23.40.0.2 WHQL [22/02/2024]
Drivers - 3160/7260/7265C : 20.100.5.1 WHQL [17/04/2019]
- Press Windows key + X > Device Manager > Right-click on your Intel Bluetooth device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (BT_Intel_v...) > Check the Include subfolders option > Next
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Intel Ethernet/WiFi/Bluetooth controller.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
608 REPLIES 608
MoKiChU
Level 40
Hi everyone,
Drivers - 9xxx/AX2xx : 22.20.0.6 WHQL [30/11/2020]
Thread updated.
MoKiChU
Level 40
Hi everyone,
Drivers - 8xxx/9xxx/AX2xx : 22.20.0.3 WHQL [27/11/2020]
Thread updated.
Hi MoKiChU, thx for driver updates..
Zardoc
Hi MoKiChU,
Here I am again with a request about I225 chip.
As you know the INF file created a reoccurring event 27 issues and updates were eventually out creating a fix.
Unfortunately, this issue is happening with the new I225 chip. I get Event 27
The description for Event ID 27 from source e2fexpress cannot be found.
Either the component that raises this event is not installed on your local computer or the installation is corrupted.
The only issue is that the message now is e2dexpress
FRENCH (La description de l’ID d’événement 27 dans la source e2fexpress est introuvable. Le composant qui a déclenché cet événement n’est pas installé sur l’ordinateur local ou l’installation est endommagée. Vous pouvez installer ou réparer le composant sur l’ordinateur local.)
Here is the ID of the Chip
PCI\VEN_8086&DEV_15F3&SUBSYS_87D21043&REV_03
Isa there a fix for .INF to stop errors?
Thanks
MoKiChU
Level 40
Zardoc wrote:
Hi MoKiChU,
Thanks
- If you have Intel Network Connections in your programs, uninstall it and restart your PC.
- Launch Driver Store Explorer > Check the boxes of all versions of this driver .inf (if you find them) : e2f68.inf > Check the box "Force Deletion" then click on the "Delete Driver" button then restart your PC.
- Install your drivers from this thread by following Instal/Update Process. You need this drivers package for your motherboard :
Drivers - I22x-V (2.5GbE)
Also for your WiFi & Bluetooth :
- If you have Intel PROSet/Wireless Software and/or Intel Wireless Bluetooth in your programs, uninstall them and restart your PC.
Even after install,
Unfortunately I still have the event 27 issue from the .INF
La description de levenenement 27 dans la source e2fexpress est introuvable. Le composant qui a déclencher cet evenement nest pas installer sur lordinateur local ou linstallation est endommager. Vous pouvez installer ou reparer le composant sur lordinateur local.
Si levenement provient dun autre ordinateur, les informations daffichage doivent etre enregistrer avec levenement.
Les informations suivantes etaient incluses avec levenement:
Intel(R) Ethernet Controller (3) I225-V
Zardoc wrote:
Even after install,
Try to switch to 1GbE (French : Gestionnaire de peripheriques > Intel(R) Ethernet Controller (3) I225-V > Right click Proprietes > Avance > Vitesse et duplex : 1.0 Gbit/s Duplex integral), if switching to 1GbE fixes your issue, it's an Intel known issue : https://cdrdv2.intel.com/v1/dl/getContent/621661
Hi MoKiChU,
Nope that didn't work. I saw in an other thread that it seems to be an .inf config.
If you find anything let me know.
Thanks.
BTW a bunch of VSS errors :rolleyes:
piratino
jmzjmz wrote:
Maybe MoKiChU could help here.
I also have have the Intel I219-V and sometimes experience connection loss while high bandwidth usage, and would like to know what the latest Firmware for that controller is, and if MoKiChU could provide that.
I also found there is a new Firmware (Intel I21x Lan controller Firmware Version 3.30, posted 05 Feb 2021) on station-driv..., but i am not sure if this is actually applicable here.
Regards
But is that a firmware or a driver? Because if it's a firmware is it maybe something that is intended to be flashed on the Ethernet chip or something...(?)
MoKiChU
Level 40
Hi everyone,
Drivers - 9xxx/AX2xx : 22.30.0.11 WHQL [20/01/2021]
Thread updated.
