[DRIVERS] Intel Ethernet/WiFi/Bluetooth
MoKiChU
Level 40
Hi everyone,
- Intel Ethernet Drivers (Drivers Only) :
Drivers - I225/I226 - Windows 11 : 2.1.4.3 WHQL [20/02/2024]
Drivers - I225/I226 - Windows 10 : 1.1.4.43 WHQL [15/02/2024]
Drivers - I219 (≥ Rev. 18) - Windows 11 : 20.0.2.10 WHQL [12/03/2024]
Drivers - I217/I218/I219 - Windows 10/11 : 12.19.2.60 WHQL [19/02/2024]
Drivers - I210/I211 - Windows 11 : 14.0.5.0 WHQL [08/02/2024]
Drivers - I210/I211 - Windows 10 : 14.0.5.0 WHQL [08/02/2024]
Drivers - 82579 - Windows 10 : 12.15.31.4 WHQL [25/07/2016]
Download - I225/I226 - Windows 11 : Link
Download - I225/I226 - Windows 10 : Link
Download - I219 (≥ Rev. 18) - Windows 11 : Link
Download - I217/I218/I219 - Windows 10/11 : Link
Download - I210/I211 - Windows 11 : Link
Download - I210/I211 - Windows 10 : Link
Download - 82579 - Windows 10 : Link
Install/Update Process :
- Press Windows key + X > Device Manager > Right-click on your Intel Ethernet device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (ETHERNET_Intel_v...) > Next
- Intel WiFi Drivers (Drivers Only) :
Drivers - 9xxx/AXxxx/BExxx : 23.50.0.6 WHQL [14/04/2024]
Drivers - 8xxx : 22.200.2.1 WHQL [09/03/2023]
Drivers - 3165/3168/7265D : 23.40.0.4 WHQL [10/03/2024]
Drivers - 3160/7260/7265C : 18.33.17.1 WHQL [29/04/2019]
Download - 9xxx/AXxxx/BExxx : Link
Download - 8xxx : Link
Download - 3165/3168/7265D : Link
Download - 3160/7260/7265C : Link
- Press Windows key + X > Device Manager > Right-click on your Intel WiFi device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (WiFi_Intel_v...) > Next
- Intel Bluetooth Drivers (Drivers Only) :
Drivers - 9xxx/AXxxx/BExxx : 23.60.0.1 WHQL [01/05/2024]
Drivers - 8xxx : 22.200.0.2 WHQL [15/12/2022]
Drivers - 3165/3168/7265D : 23.40.0.2 WHQL [22/02/2024]
Drivers - 3160/7260/7265C : 20.100.5.1 WHQL [17/04/2019]
- Press Windows key + X > Device Manager > Right-click on your Intel Bluetooth device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (BT_Intel_v...) > Check the Include subfolders option > Next
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Intel Ethernet/WiFi/Bluetooth controller.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
583 REPLIES 583
Hi, It's better to be specific about the version so I guess you do refer to e2fn.inf DriverVer = 10/03/2023,2.1.4.2 ?
I have 2 computers based on the  ASUS TUF GAMING Z790-PLUS WIFI motherboard which loads this specific driver without any problems.
Never heard of bricking a network device ever by a driver (might just be me) but I guess that would be highly unlikely. But then I can't comment on a remote issue but maybe (force) delete all drivers with DriverStoreExplorer and let Windows load a default driver to start 'default'?
MoKiChU
Level 40
Hi everyone,
Thread updated.
MoKiChU
Level 40
Hi everyone,
Thread updated.
Xlalexlx
Hey in having issues with ethernet and wifi connection. I installed the lan and wifi drivers from asus for my z790 pro but when I run them it says not compatible with windows even though it's the correct version.
I don't know much about pc this is my first build and I've been stuck on this for a week. I saw your list of links but don't know which ones I'll need.
MoKiChU
Level 40
Hi everyone,
Thread updated.
MoKiChU
Level 40
Hi everyone,
Drivers - 9xxx/AXxxx/BExxx : 23.50.0.2 WHQL [05/04/2024]
Thread updated.
MrAgapiGC
both in, no issues. And i am using a lot bt now than ever.  thanks boss!
Learn, Play Enjoy!
Thechin
intel recommends not installing the Proset/Wireless Software unless your in IT and that they are no longer updating it.  I have the drivers on my PC but I have no Control panel or interface.
Gamestress
Hi, Intel released a new Ethernet driverpack
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.h...
Pack 29.1 contains newer drivers for example:
Drivers - I217/I218/I219 - Windows 10/11 : 12.19.2.57 WHQL [25/11/2023] -> 12.19.2.60 [19/02/2024]
Drivers - I225/I226 - Windows 11 : 2.1.4.2 WHQL [03/10/2023] -> 2.1.4.3 [20/02/2024]
Retired
Not applicable
I only put how this instaals on my machine... Driver versions obviously vary.
Drivers - I210/I211 - Windows 11 : 14.0.6.0 WHQL [15/03/2024] included in the above mentioned 29.1 release as well
