[DRIVERS] Intel Ethernet/WiFi/Bluetooth
MoKiChU
Level 40
Hi everyone,
- Intel Ethernet Drivers (Drivers Only) :
Drivers - I225/I226 - Windows 11 : 2.1.4.2 WHQL [03/10/2023]
Drivers - I225/I226 - Windows 10 : 1.1.4.42 WHQL [29/06/2023]
Drivers - I219 (≥ Rev. 18) - Windows 11 : 20.0.2.7 WHQL [14/01/2024]
Drivers - I217/I218/I219 - Windows 10/11 : 12.19.2.57 WHQL [25/11/2023]
Drivers - I210/I211 - Windows 11 : 14.0.2.0 WHQL [24/11/2023]
Drivers - I210/I211 - Windows 10 : 14.0.2.0 WHQL [25/09/2023]
Drivers - 82579 - Windows 10 : 12.15.31.4 WHQL [25/07/2016]
Download - I225/I226 - Windows 11 : Link
Download - I225/I226 - Windows 10 : Link
Download - I219 (≥ Rev. 18) - Windows 11 : Link
Download - I217/I218/I219 - Windows 10/11 : Link
Download - I210/I211 - Windows 11 : Link
Download - I210/I211 - Windows 10 : Link
Download - 82579 - Windows 10 : Link
Install/Update Process :
- Press Windows key + X > Device Manager > Right-click on your Intel Ethernet device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (ETHERNET_Intel_v...) > Next
- Intel WiFi Drivers (Drivers Only) :
Drivers - 9xxx/AXxxx/BExxx : 23.40.0.4 WHQL [10/03/2024]
Drivers - 8xxx : 22.200.2.1 WHQL [09/03/2023]
Drivers - 3165/3168/7265D : 23.20.1.1 WHQL [20/12/2023]
Drivers - 3160/7260/7265C : 18.33.17.1 WHQL [29/04/2019]
Download - 9xxx/AXxxx/BExxx : Link
Download - 8xxx : Link
Download - 3165/3168/7265D : Link
Download - 3160/7260/7265C : Link
- Press Windows key + X > Device Manager > Right-click on your Intel WiFi device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (WiFi_Intel_v...) > Next
- Intel Bluetooth Drivers (Drivers Only) :
Drivers - 9xxx/AXxxx/BExxx : 23.40.0.2 WHQL [22/02/2024]
Drivers - 8xxx : 22.200.0.2 WHQL [15/12/2022]
Drivers - 3165/3168/7265D : 23.20.0.3 WHQL [28/11/2023]
Drivers - 3160/7260/7265C : 20.100.5.1 WHQL [17/04/2019]
- Press Windows key + X > Device Manager > Right-click on your Intel Bluetooth device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (BT_Intel_v...) > Check the Include subfolders option > Next
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Intel Ethernet/WiFi/Bluetooth controller.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
572 REPLIES 572
ok ty, tell me if you find any solution
Did you install through the device manager? Thats the only way I can get any of these newer drivers to halfway work.
MoKiChU
Level 40
Hi everyone,
Thread updated.
dragonwolf5589
Hi, i got a new ssd and reinstalled windows 11 from clean install - Some reason when i install the Drivers - I225/I226 - Windows 11 : 2.1.4.2 WHQL [03/10/2023] driver - my pc wont stay asleep and i CAN'T untick "wake from lan" on the ethernet properties. if i remove the driver i can, but when i install the driver its all greyed out? anyone know why? it worked (still works) fine on my old ssd drive but not on my fresh install of windows 11 unless i remove the driver entirely and then i can either tick "only allow magic packets" or untick the whole wake from lan.
its the correct driver and it works better when i install the driver, just not sure why it stops "power management" tab on the ethernet properties to entirely all grey out.
juiceof2limes
I use same driver on W11 and installed during the install phase (where you would normally add drivers for disk access if needed).  Had same issue with PC not wanting to stay asleep until I ticked "Only allow a Magic Packet" etc.    Other than that, I have no issues with the driver.
Did you install a mobo supplied driver before applying this version?  If yes,  you could uninstall that and then simply apply this driver.
nope, it had no drivers until i installed this as i had downloaded this before reinstalling and installed offline/ not connected to internet.
i cant tick magic packet at all the whole thing is greyed out unless i uninstall and have "microsoft basic ethernet" drivers loaded
MoKiChU
Level 40
Hi everyone,
Drivers - 9xxx/AXxxx/BExxx : 23.30.2.1 WHQL [07/02/2024]
Thread updated.
fisher94
Hi, i see that there are 2 versions of I219v ethernet driver at first page. Which one should i install?
First, check which revision you have by referring to the number in parentheses in the naming of your device in your Device Manager :
Intel(R) Ethernet Connection (Rev.) I219-V
- If you do not have revision 18 or higher, whether you are using Windows 10 or Windows 11, there is no choice to make, just use this one :
- If you have revision 18 or higher and you are using Windows 11, use this one :
- If you have revision 18 or higher and you are using Windows 10, use this one :
