[DRIVERS] Intel Ethernet/WiFi/Bluetooth
MoKiChU
Level 40
Hi everyone,
- Intel Ethernet Drivers (Drivers Only) :
Drivers - I225/I226 - Windows 11 : 2.1.5.4 WHQL [02/04/2025]
Drivers - I225/I226 - Windows 10 : 1.1.4.45 WHQL [02/03/2025]
Drivers - I217/I218/I219 - Windows 10/11 : 12.19.2.64 WHQL [19/02/2025]
Drivers - I210/I211 - Windows 11 : 14.1.22.0 WHQL [08/04/2025]
Drivers - I210/I211 - Windows 10 : 14.0.7.0 WHQL [08/04/2025]
Drivers - 82579 - Windows 10 : 12.15.31.4 WHQL [25/07/2016]
Download - I225/I226 - Windows 11 : Link
Download - I225/I226 - Windows 10 : Link
Download - I217/I218/I219 - Windows 10/11 : Link
Download - I210/I211 - Windows 11 : Link
Download - I210/I211 - Windows 10 : Link
Download - 82579 - Windows 10 : Link
Install/Update Process :
- Press Windows key + X > Device Manager > Right-click on your Intel Ethernet device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (ETHERNET_Intel_v...) > Next
- Intel WiFi Drivers (Drivers Only) :
Drivers - 9xxx/AXxxx/BExxx : 23.150.0.4 WHQL [12/06/2025]
Drivers - 8xxx : 22.200.2.1 WHQL [09/03/2023]
Drivers - 3165/3168/7265D : 23.40.1.1 WHQL [20/03/2024]
Drivers - 3160/7260/7265C : 18.33.17.1 WHQL [29/04/2019]
Download - 9xxx/AXxxx/BExxx : Link
Download - 8xxx : Link
Download - 3165/3168/7265D : Link
Download - 3160/7260/7265C : Link
- Press Windows key + X > Device Manager > Right-click on your Intel WiFi device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (WiFi_Intel_v...) > Next
- Intel Bluetooth Drivers (Drivers Only) :
Drivers - 9xxx/AXxxx/BExxx : 23.150.0.3 WHQL [09/06/2025]
Drivers - 8xxx : 22.200.0.2 WHQL [15/12/2022]
Drivers - 3165/3168/7265D : 23.40.0.2 WHQL [22/02/2024]
Drivers - 3160/7260/7265C : 20.100.5.1 WHQL [17/04/2019]
- Press Windows key + X > Device Manager > Right-click on your Intel Bluetooth device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (BT_Intel_v...) > Check the Include subfolders option > Next
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Intel Ethernet/WiFi/Bluetooth controller.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
648 REPLIES 648
MoKiChU
Level 40
Hi everyone,
Drivers - 9xxx/AXxxx/BExxx : 23.30.2.1 WHQL [07/02/2024]
Thread updated.
fisher94
Hi, i see that there are 2 versions of I219v ethernet driver at first page. Which one should i install?
fisher94
So i installed the right one. Thanks for clarifying.
MoKiChU
Level 40
Hi everyone,
Drivers - 9xxx/AXxxx/BExxx : 23.40.0.4 WHQL [10/03/2024]
Thread updated.
MoKiChU
Level 40
Hi everyone,
Drivers - 9xxx/AXxxx/BExxx : 23.40.0.2 WHQL [22/02/2024]
Thread updated.
MrHannibal66
I'm still havin issue with drivers - I225
whats the latest version for I225
My motherboard is B550-F
Using win11 23H2 latest version
kist
Hello
i installed the latest version of ethernet driver but ethernet continue to not working.
In the events i see a starting issue "e2fnexpress" with error "0xC00000E5"
Do you know this issue ?
Same issue for me 😞
MoKiChU
Level 40
Hi everyone,
Intel I225/I226 Ethernet controllers users :
As reminder :
- If you are using Windows 10 : There is no choice to make, you must use Windows 10/NDIS Drivers (1.x.x.x).
- If you are using Windows 11 : I recommend that you try Windows 11/NetAdapterCx Drivers (2.x.x.x) type first and switch to Windows 10/NDIS Drivers (1.x.x.x) type only if you have an issue :
Windows 11/NetAdapterCx Drivers (2.x.x.x) : More efficient than NDIS drivers type because of more low level access to the controller than NDIS drivers type, but can generate side effects due to the non-support of NetAdapterCx by other apps or system addons features. If you encounter any issue with NetAdapterCx drivers type, switch to the NDIS drivers type.
Windows 10/NDIS Drivers (1.x.x.x) : NDIS drivers type is the legacy drivers type used for all other Intel Ethernet gigabit controllers drivers whether for Windows 10 drivers or Windows 11 drivers, this drivers type will give you better stability/compatibility.
I tried the version 2.x.x.x which give me the error  "e2fnexpress"0xC00000E5" and when i tried the version 1.x.x.x i got the error "device cannot start ( code 10 )"
