[DRIVERS] Intel Ethernet/WiFi/Bluetooth
MoKiChU
Level 40
Hi everyone,
- Intel Ethernet Drivers (Drivers Only) :
Drivers - I225/I226 - Windows 11 : 2.1.4.3 WHQL [20/02/2024]
Drivers - I225/I226 - Windows 10 : 1.1.4.43 WHQL [15/02/2024]
Drivers - I217/I218/I219 - Windows 10/11 : 12.19.2.62 WHQL [18/07/2024]
Drivers - I210/I211 - Windows 11 : 14.1.5.0 WHQL [15/11/2024]
Drivers - I210/I211 - Windows 10 : 14.0.5.0 WHQL [15/11/2024]
Drivers - 82579 - Windows 10 : 12.15.31.4 WHQL [25/07/2016]
Download - I225/I226 - Windows 11 : Link
Download - I225/I226 - Windows 10 : Link
Download - I217/I218/I219 - Windows 10/11 : Link
Download - I210/I211 - Windows 11 : Link
Download - I210/I211 - Windows 10 : Link
Download - 82579 - Windows 10 : Link
Install/Update Process :
- Press Windows key + X > Device Manager > Right-click on your Intel Ethernet device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (ETHERNET_Intel_v...) > Next
- Intel WiFi Drivers (Drivers Only) :
Drivers - 9xxx/AXxxx/BExxx : 23.110.0.5 WHQL [02/01/2025]
Drivers - 8xxx : 22.200.2.1 WHQL [09/03/2023]
Drivers - 3165/3168/7265D : 23.40.1.1 WHQL [20/03/2024]
Drivers - 3160/7260/7265C : 18.33.17.1 WHQL [29/04/2019]
Download - 9xxx/AXxxx/BExxx : Link
Download - 8xxx : Link
Download - 3165/3168/7265D : Link
Download - 3160/7260/7265C : Link
- Press Windows key + X > Device Manager > Right-click on your Intel WiFi device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (WiFi_Intel_v...) > Next
- Intel Bluetooth Drivers (Drivers Only) :
Drivers - BExx2 : 23.100.1.1 WHQL [20/11/2024]
Drivers - AXxx1/BExx0/BExx1 : 23.110.0.4 WHQL [18/12/2024]
Drivers - 9xxx/AXxx0 : 23.100.0.4 WHQL [12/11/2024]
Drivers - 8xxx : 22.200.0.2 WHQL [15/12/2022]
Drivers - 3165/3168/7265D : 23.40.0.2 WHQL [22/02/2024]
Drivers - 3160/7260/7265C : 20.100.5.1 WHQL [17/04/2019]
Download - BExx2 : Link
Download - AXxx1/BExx0/BExx1 : Link
Download - 9xxx/AXxx0 : Link
- Press Windows key + X > Device Manager > Right-click on your Intel Bluetooth device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (BT_Intel_v...) > Check the Include subfolders option > Next
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Intel Ethernet/WiFi/Bluetooth controller.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).
619 REPLIES 619
MoKiChU
Level 40
Hi everyone,
Drivers - 8xxx/9xxx/AX2xx : 22.40.0.2 WHQL [16/02/2021]
Thread updated.
MoKiChU
Level 40
Hi everyone,
Drivers - I210/I211 - Windows 10 : 12.18.12.1 WHQL [23/02/2021]
Thread updated.
beembuilds wrote:
Sorry to bug Mr. M, but what BT driver should I download?
I just upgraded my mobo too the Rog Maximus XII Formula.
Thank you sir.
You need these firmware/drivers for your ASUS ROG Maximus XII Formula motherboard :
[FIRMWARE] Intel ME (H470/Z490)
[DRIVERS] Intel Chipset/MEI/SATA/VMD (1xx/2xx/3xx/4xx/5xx/6xx)
- Intel Chipset Drivers
- Intel MEI Drivers (Drivers Only)
- Intel SATA AHCI-RAID Drivers (Drivers Only) :
Drivers - 4xx/5xx
Drivers - I225
Drivers - 8xxx/9xxx/AXxxx
[DRIVERS] Marvell/Aquantia Ethernet
[DRIVERS] Realtek Audio (MB | Intel 2xx/3xx/4xx/5xx/6xx & AMD 3xx/4xx/5xx/6xx)
You have an ASUS ROG SS3|DTS Sound Unbound motherboard, so :
You need Realtek Audio Drivers (UAD - ASUS ROG SS3-DTS MB) from the first post of the thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
MoKiChU
Level 40
Hi everyone,
Drivers - I22x-V (2.5GbE) : 1.0.2.13 WHQL [06/01/2021]
Thread updated.
MoKiChU wrote:
Hi everyone,
Drivers - I21x-V (1.0GbE) : 12.19.1.35 WHQL [05/01/2021]
Download - I21x-V (1.0GbE) : Link
Thread updated.
Thank you @MoKiChU. STAY WELL! Really appreciate your efforts.
Hi MoKiChU, thx for driver updates..
MoKiChU wrote:
Hi everyone,
Download - I22x-V (2.5GbE) : Link
Thread updated.
Thanks - I right clicked the .inf and installed it. Rebooted, but no luck. The driver doesn't seem to work/take effect.
ROG STRIX Z590-E GAMING WIFI with 2 x Intel® I225-V 2.5Gb Ethernet\
88536
MoKiChU
Level 40
Hi everyone,
Drivers - I21x-V (1.0GbE) : 12.19.1.37 WHQL [10/02/2021]
Thread updated.
MoKiChU wrote:
Hi everyone,
Thread updated.
Got it, thanks:)
88328
piratino
Hello there!
Have you ever experienced issues in LAN speed like if you were going to fast-ethernet 100 Mbs ??
I am having a strange behaviors, like if I'm limited as on Speedtest I get between 80 and 90 Mbs on both upload and download, while I should go at 800 Mbs as I am on fiber FTTH.
I was able to go to those speed, but since a while (and I frankly don't know from when) I can't anymore.
It is not my internet speed as with my laptop with gigabit ethernet and connected to the modem with the cable like the pc I am able to reach 800 Mbs.
EDIT: forgot to mention that in the Advanced features of the drivers properties, under Speed & Duplex I have Auto Negotiation set as default.
If I try to force it to 1.0 Gbps Full Duplex I get no connection, and the icon of my ethernet adapter in Dial-Up Networking has a red big X on it, being unable to connect to the lan network.
If I force it to 100 Mbps Full Duplex, everything works perfectly.
And my cables and router are still the as always, never did any hardware change.
Any suggestions on what I could try?
Thank you in advise.
