B650M-R RGB Brightness Control Missing in Armoury Crate – High LED Brightness Issue
ROGodzkv7qadfgh
Hi everyone, I recently bought an ASUS ROG B650M-R motherboard about 2 weeks ago. The box and retailer stated that it supports RGB lighting, which was one of the main reasons I chose this motherboard. I can change the colors of my fans and LED components using Armoury Crate, but I cannot find any option to adjust brightness. I have multiple fans and LED strips, and the lights are extremely bright. This is uncomfortable and potentially dangerous for someone with epilepsy. I have had to keep all LEDs turned off for the past two weeks. My questions are: 1. Is there any hidden brightness control in Armoury Crate or BIOS for B650M-R? 2. Are there any recommended workarounds, either software or hardware, to safely reduce RGB brightness? 3. Can third-party software such as OpenRGB work reliably with this motherboard? Any guidance would be greatly appreciated because the brightness of the LEDs is a serious issue for me. Thank you very much.
nttquan
Having the same issue here, no luck finding brightness function for addresable strip, only for Asus devices can be able to adjust
