ROG Elite Rewards - Product Registration Low Points Given
DryreL
Hi there,
I started registering my ROG products for points. I got 2500 points for the ROG Strix G16 but 100 points for the ROG Gladius III Wireless mouse.
A really low score was given for the mouse. Was there a mistake? You can't get anything with 100 points!!
4 REPLIES 4
DryreL
Update: I found a website which shows the points given for the registered product.
Still, 100 points is really low.
invasioned
The points awarded for registering products can vary based on the manufacturer's policies, promotions, and the perceived value of the registered product. Gaming laptops or high-end hardware components often receive more points compared to accessories like mice.
If you believe there might be a mistake or if you have concerns about the points allocation, I recommend reaching out directly to the customer support or loyalty program support of the company that manages the ROG (Republic of Gamers) product registration and points system. They should be able to provide clarification on the points allocation and address any issues or discrepancies you might have encountered.
Contacting customer support or checking the terms and conditions of the loyalty program should give you more information about how points are calculated and whether there might be any special promotions or conditions affecting the points allocation for specific products.
jkuchcik
Yesterday, I registered the following:
  • ROG Strix Z790-F Gaming WIFI II - Motherboard
  • ROG STRIX RTX 4080 O16G Gaming - GPU
  • PG42UQ - OLED Monitor
  • ROG Balteus Qi
  • ROG P702
I received an e-mail acknowledging that they received the registration and asked that I provide a review (which I did), although I have not received any points towards my Elite Rewards.    Based on these registrations, and upwards of $2K in spend, I would guess that I should get some points right?  Lets see what happens.
Does anyone know of the turnaround time for when they grant the points?
I usually get mine the next day or in 2 days max.
