Welcome back to ROG Phone Mastery!
In this edition, we're introducing a useful feature you might not know about—the "Auto-Repeat Tap" function!
With this feature, you can perform up to four taps per second by simply holding down the AirTriggers. You can also set the vibration speed according to your preferences. Whether it's for rapid attacks in MMORPGs or continuous shooting in FPS games, this function will enhance your gaming experience! Let's take a look at how to use the "Auto-Repeat Tap" function.
How to Use "Auto-Repeat Tap"
Open Game Genie: Start by launching Game Genie.
Select AirTriggers: Tap on the AirTriggers option.
Choose Touch: Tap on Touch settings.
Find Auto-Repeat Tap: Tap on "Auto-Repeat Tap" to locate the settings.
Customize Your Settings
Number of taps per second when long press: Set the number of taps per second according to your preference.
Constant Vibration: Adjust the vibration speed based on your liking.
(🎮Tip: Setting it to High will make your phone vibrate rapidly, which is perfect for FPS game shooting buttons.)
Give this exciting feature a try and see how it can enhance your gaming performance!
Further Reading
To explore more about enhancing your ROG Phone gaming experience, check out the following topics:
ROG Phone Mastery:Ultrasonic buttons
ROG Phone Mastery : Macro
ROG Phone Mastery:Gyroscope Aiming
ROG Phone Mastery:Shooting Assist
