Urgent help upgraded from 1366 to 1150
Dannyboy2014
Hey guys and gals
I have a alienware Area 51 alx
I upgrade my mobo from a 1366 socket to MAXIMUS VI HERO 1150
The issue I'm having is the cpu bracket (the black screw thing on the back of the motherboard) won't fit the new mobo which is not allowing me to use my previous alienware liquid cooling fan any ideas of some sort of conversion bracket kit as I really don't wanna have to buy a new fan
Thanks any advice is much appreciated
Danny
PowerOver9K
You have to buy a new fan unfortunately. They didn't mean for you to switch that out. You can look around for generic 1150 backplates but I doubt that will work.
Mobo: Rampage IV BE | CPU: i7-4930@4.5ghz Hexacore | RAM: 32GB Corsair V-Pro | GPU: 4xR9 290X Quadfire | PSU: eVGA P2 SuperNOVA 1000W\G2 850W | Chassis: NZXT Phantom 820 | Cooling: XSPC Raystorm CPU Block\4xEK 290X Block\2x Laing D5\XSPC Dual Bay Res\Phobya G-Changer 1080 External Rad\Alphacool 140UT60\XSPC AX360 | Fan Con: Lamptron CW611 | Tube: Primochill Adv. LRT Bloodshed Red | 3xCrossover 27" 2560x1440 Monitors | Build Log of Insanity
kkn
Level 14
1366 and 1150 is 2 diffrent sockets and hole placements.
so no it will not work at all.
