[Scratch build] Project :: [GT] Cube mATX , Start!!
iD2ROG
Welcome!!!
See all project at my blog here :: iD2CNC.wordpress.com
Project Name :: [GT] Cube mATX
Project concept:: It not just system, It your style
Specification ::
- Materials:: Acrylic
- Colors:: Black/White
- Tags Colors:: Red/White/Yellow/Green/Blue/Orange
- Motherboard Sizes: mATX
- 5.25″ Drive bays:: 2
- HDD 3.5″:: 2
- HDD 2.5″:: 2
- Power Supply:: 2
- Cooling Rear:: 1 x 120mm
- Cooling Top:: 3 x 120mm
- PCI Slots:: x 4
- Radiator thickness:: 30/35mm (will fit with 45mm thickness)
- Maximum CPU Cooler Height:: 165mm
- Dimensions (WxHxD):: 300 x 330 x 482mm
- Radiator support:: 1x 240mm / 1x 360mm
Features ::
- Support Right-Hand Style /Left-Hand Style
- 4 x Front panel style
- 6 x Front tags color
- Transparent side panel
- Transparent front panel
- Transparent GPU panel
- Cable management
Multiple Tags Color ::
6 Colors Tags , compatible with components ::
Detail ::
Drawing Detail ::
Support Both Right-Hand Style cases or Left-Hand Style cases ::
Get 4 Style font panel :: (Just flip it)
All Project by ::
Hope you like it.
PS. I'm not good in English , If i make you confuse please feel free to ask me.
9 REPLIES 9
hero1
Nice idea. You mentioned that you will have 2 PSU. I think you meant to say 1 up there on your parts list. I like the red and white renders. If I had to choose one it will have to be Red even though I like both colour scheme. All the best with the mod and I will be watching this as it comes to life.
i7 4770K| ASUS Maximus VI Formula| G. Skill Ripjaws Z 16 GB 1866 MHz| 256 Samsung 830| AMD R9 290X CF| Silverstone S. E 1000W| Creative SB Z| Samsung DVDRW| Dell 27" U2713HM| Logitech G710+| Corsair M60 and G27 Racing Wheel| Sennheiser PC 350
Cooling: 2 x 360 mm EKWB XTX rads, EK-D5 Vario w/ Plexi Top, X3 Res, Supr Plexi Copper, CSQ fittings, Noctua Fans
Thank you, i need to complete this scratch but i can supply the components , i have no budget anymore just spent it for build aluminum CNC. And i'll try to find sponsorship but can't find how to contact who have proper authorize.
For PSU , it have 2 but use only 1 or 2 . i design it for compatible with righ-hand or left-hand style.
chrsplmr
Level 18
Black & Red ...
Great renders. Best of Luck..c.
iD2ROG
Before start new project for build acrylic computer case from scratch i just need to lift CNC up because it not convenient when using CNC and re-wiring limit switch by using shields wire to protect noise from spindle and stepper motor, After finish it make my small room look very small than ever.
Wood table base ::
iD2ROG
Project start , will update soon.
I will be coming back soon thanks for the great article.
I need to open new thread because it can not change thread title , this was not planning anymore.
Hello, After finish my CNC v.2.0 for long time now my new design and improve some issued from v.2.0 , my cnc design v.2.1 will release soon and will finish CNC plans document soon.
More detail please visit --> iD2CNC.com or iD2CNC.wordpress.com
New video update --> id2cnc.com
