ROG Hyperion GR701 case- connect secound usb c cable
peteruswiss
hello to everyone,
My new Hyperion case has two usb c connecting cables from case side but my Maximus Z790 Extreme just one usb c connector.
I searched for adapters or cables in the net but didn't found something, not even the ASUS customer support was able to support me with a solution!
Maybe there is a workable idea from somebody here in the forum- thank you for ideas!
Murph_9000
Level 14
The Maximus Z790 Extreme has the single USB 3.2 2x2 type E header and a Thunderbolt 4 type C header.  I don't know exactly what internal cables the Hyperion has from its front panel (can't find a picture or manual for it), but there are both styles of C-to-E / E-to-C adapters out there, which should let you use the TB4 port for the 2nd type C (i.e. to plug a C cable into an E header, or an E cable into a C header).
Thanky you very much Murph-9000 for your feedback!  USB 3.2 2x2 (Gen 2x2) Typ C  cables.and two USB 3.2. (Gen 1) cables. I was just wondered that there were no infos regarding this. Anyway I will search for an adapter.
Thank you so much for your engagement !
NAMOR2019
I added one of the many add-on cards to connect that 2nd USB Cable. Mine was only 10Gbps but if you want a 20 Gbps see here on Amazon they sell such;
https://www.amazon.com/dp/B08Y5JT2BS/?coliid=I1KJGQE7H89QMY&colid=1JNJXYAJ6TKRR&psc=1&ref_=list_c_wl...
Respect!
