12-20-2018 11:44 PM
12-21-2018 10:38 AM
12-21-2018 11:37 AM
12-21-2018 11:23 PM
12-21-2018 04:52 PM
12-21-2018 09:30 PM
12-21-2018 11:25 PM
JustinThyme wrote:
Too many on the market now. I’m actually looking to dump the aura anabled HB and just cover up that ugly thing that comes in the box. Zotac makes one that’s solid black with a single white led in the middle to show its active with Zero branding on it! I’m sitting on two of the ROG of different spacings because they can never make up their mind on exactly what 3 slots means.*
12-22-2018 09:40 PM
rjbarker wrote:
I now thats the problem...instead of 4 slot...3 slot...2 slot spacing etc etc etc ...how about simple 2 way 60mm or 2 way / 3 way / 4 way 80mm ......I think its a conspiracy to get folks to purchase the wrong ones ..... 😉
12-23-2018 03:21 PM
JustinThyme wrote:
Yes it’s annoying as no one uses the same standard with the naming conventions. ASUS even changes from one build to the next. Right now most SLI spacing if you use the recommended slots is referred to as 3 slot spacing yet you go to buy an SLI waterblock bridge and it goes by a different standard. Some count slot to spot, some count bottom of first card to slot of next, some are spaces between cards. *The all use the same darn slot spacing so why not just give out measurements? Nah can’t be doing that, we need to keep the confusion so we can sell 2 or 3 different non refundable bridges. **
12-23-2018 03:50 PM
