PWC: Project White Craze
faheemrazzaq
It's time to do another build log named PWC: Project White Craze. Last year I finished the Project Silicon Talisman and this project will be inheriting a lot of bits and pieces from that. It is more of a refresh than a scratch build.
The key difference, hardware wise, will be upgrade to the x99 platform. I am keeping my gpu's as they are still doing an excellent job for me.
Ofcourse I will be using the hard line tubing and a shift from 'Red-White' to 'White' only theme.
Here is the list of all the components:
CPU: Intel® Core™ i7-5820K
RAM: 32GB Corsair Vengeance 2666MHz DDR4 (4x8gb)
Motherboard: ASUS X99-A II
GPUs: 2x Sli Nvidia Galax/KFA2 GeForce GTX 980 Hall of Fame (HOF)
PSU: SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply
Case: Phanteks Enthoo Luxe Full Tower Case
Cabling: White sleeved cables.
Storage: A combination of SSD's and HDD's
Watercooling loop:
Coolant: Mayhems Pastel Ice White
CPU Cooler: EK Water Blocks EK-Supremacy EVO
GPU Blocks by Diamond Cooling - White Acetal
Reservoir: Phobya 150 Balancer
14/10mm Acrylic Tubing
Barrows Black compression fittings
EK angle fittings
420mm Hardware Labs Black ICE Radiator GT Stealth 420
360mm Hardware Labs Black ICE Radiator GTX 360
240mm Phobya G-Changer 240 V.2
Pump 1: Swiftech MCP35X Industrial Pump 12 Volts
Pump 2: Swiftech MCP655-B Water Pump 12 Volts with EK-XTOP D5 Pump Top
2x XSPC Temperature Sensors
12 REPLIES 12
faheemrazzaq
The front radiator cover is ready. This will be installed with the dust filters.
faheemrazzaq
I have spent some time preparing this 'Edge Lit' Galax Hall of Fame logo. This will go in front of the pump and will be one of the center piece of this build. It is hand graved on a clear acrylic sheet and back of it is painted black to add some contrast. Used white led's at the bottom to light it up.
faheemrazzaq
