Project Vector (Silvertone Raven 2 Casemod Project)
tantric
Hello ROG Fans!
I just want to share my latest project. It's actually a quick modding project I had to do for local gaming event here in Manila and ASUS being one of the major sponsors of the event. Sorry for the lack of detailed worklog pics. I only had less than a week to finish this project before the event.
For this project I'll be using an old SilverStone Raven 2 Case, that I have standing here in the shop for the longest time.
here's me making a quick sketch for the case.
29180
the bare case with all the panels and internal parts dissasembled.
29181
ASUS ROG Maximus V:
29269
i used some texturized matte black vinyl decals to cover up the io port
29270
i also removed the stock mosfet heatsinks and painted them to matte black.
29271
29272
29273
29274
done!
29182
WD Velociraptors:
29275
29276
29183
27 REPLIES 27
tantric
I'm using some of my old parts for this build so I had to do a little bit of modding to make them fit into the theme.
Heatkiller 3.0 CPU waterblock
29184
after some plastidip treatment
29185
tantric
doing some test fitting on the parts inside the case.
29186
29187
i placed some vinyl decals on the copper side of the gpu waterblocks to prevent them from standing out too much and ruining the entire color scheme.
29188
29189
creating a vector layout for the side and front panels.
29191
the custom acrylic panels. fresh from the lasercutting shop.
29199
29200
i used my trusty acrylic bender to create a slightly raised edge on the acrylic.
29201
29202
after some final checking and test fitting. they are now ready for painting.
29203
tantric
the custom made psu shroud using perforated leather canvass and some scrap acrylic sheet.
29190
tantric
the custom acrylic panels fresh from the lasercutting shop.
29192
29193
i used my trusty acrylic bender to create a slightly raised bend on the acrylic panels.
29194
29195
29196
tantric
i forgot to take pics of the actual painting process, and i barely had the time to take proper pics because i only had a few days to finish the project before the event.
but i took a shot with my camphone while i was waiting for the paint to dry in my ghetto oven. (pics taken inside my car on a sunny day here in manila)
29215
i used the same perforated canvass to lineup the reverse side of the metal panels. looks cooler than just painting it matte black.
29219
29220
29218
a quick preview of the finished panels.
29223
