Project Titan Slayer
Laing1982
My first ever major watercooled pc project and decided to go with CPU, GPUs and Mobo waterblocks and double rads. Been an expensive project but is now finished, what you guys think?
7970 Matrix Platinum waterblocks are EK, along with CPU and Mobo.
35607
Expensive cards to start ripping apart, very nervous times lol
35608
35610
Cards done, Mobo and CPU coolers on, getting there.....
35609
35611
Time to start fitting this kit back in 🙂
35612
35613
Test time, no leaks, thank god 😉
35614
fans all installed, bitfenix red cables in, blood red coolant in, pretty much done now!
35615
35616
35617
35618
35619
All done, built, leak tested, ran for a week or so now with no issues.
Temps for the CPU:
28 degrees idle, 45 max under load
Temps for GPU's
27 degrees idle, 40-45 under load
Huge improvement for my cards, they were 70-80 degrees under load before i decided to watercool them. Massive temp drops!
Corsair 900D / Corsair AX1200i / AMD FX-9590 @ 4.7ghz / ASUS ROG Crosshair V Formula Z / ASUS ROG 7970 Matrix Platinum Crossfire / x2 EK Coldstream XTX 480 Radiators / x2 EK 7970 Matrix Waterblock / EK Supreme LTX CPU Waterblock / EK ASUS C5F-Z Waterblock / XSPC D5 Photon 270 Reservoir/Pump Combo / Corsair Vengeance 2133mhz / Corsair Vengeance K70 / Corsair Vengeance M65 / 120gb SSD & 2tb HDD
12 REPLIES 12
twisted1
Level 12
Nice build! I have a couple of 7970 matrix with Ek blocks also, very nice cards and they have plenty of headroom for OC. I'm running 1300Mhz gpu, rock stable for gaming on water.
Bagmup
Very nice build, don't worry about the coolant, doing maintenance is half the fun...well it is to me, i love pulling stuff apart just because. 😄
HappyBuddhaman
What size and brand sleeving did you use? Did you sleeve individual or multiple wires per sleeve? And I can't tell, did you also use red heat shrink?
