Project - The Next Level - 13-05-2012 Steel and wood
PasLis
Hi Everyone,
Its time for another project.My idea/design to build a desk inside a frame with a glass top and without feet ive done 2 times.
Version 1.
Version 2.
I dont want to make a third version so now its time for a new design.This time i go for an ergonomic design.So this is the kickoff for my new project The Next Level.
The idea is to build a design desk that can be adjust in height so everyone can sit at it by simply push a button to move it up or down.My designs always change when im building so here a drawning how its gonna look.
The desk will be watercooled and the hardware is not decided yett.More about this later.
I already bought the lifting column and this is how it looks.
The specs.
• Thrust: up to 2500 N per DL2
• Speed: up to 20 mm/s with CBD4
• Installation dimensions can be seen in the
ordering example
• Stroke length 300 mm, 350 mm, 500 mm ± 4 mm
• Colour: Natural anodized aluminium profiles and
black painted end plates or electro-galvanised
3 mm end plates
• Low noise level
• Compact and mounting friendly design
• Built-in limit switches (not adjustable)
• Dimension column: 147 x 194 mm
• Dimension 8 mm end plates: 160 x 244 x 8 mm
• Dimension 3 mm end plates: flush with the
profiles
• Each column is fitted with a 740 mm ± 60 mm
straight black cable with an 8-pole AMP plug or
100 mm mini-fit cable
• Dynamic bending moment (at 100% stroke
length):
My+/Mx+ = 250 Nm and My-/Mx- = 200 Nm
And a little movie how it works.
http://www.youtube.com/watch?v=61hPwaFKs1E
213 REPLIES 213
Update 28.
First i mounted the waterblock,backplate and the twincoonect on the gpu.After that i finisht bending the second loop.
Today i picked up the oak top at my work and put it on top off the desk just for the looks and it even looks better then i expect.
The pictures speak for themselfs so have fun watching.
This was it for today.
Thanks to my sponsors :
PasLis
Thanks a lot Gipi49. 😄
tadhp
One word ............. Beautiful :cool:
CPU : Intel i7-3960X MB : Rampage IV Extreme 3101 Mem : G.SKILL F3-17000CL9Q2-32GBZH
GPU : MSI R7970 Lightning PSU : Corsair 1000W OS : W 7 Ultimate Corsair H100 Water cool
SSD : 120GB Kingston Hyper X SSD : 512GB Samsung 480 Pro HDD : 2X 1T WD Speaker : Bose companion 5
Cooler Master
HAF-X Monitor : ASUS PB278Q
PasLis
Thanks a lot tadhp. 😄
Area_66
Level 11
Honestly it's the first time I like a PC build in a desk, it's beautiful and a lot of attention to the small detail..
PasLis
Thanks a lot Area 66. 😄
Im a sheetmetal worker PasLis, your work is outstanding and attention to detail is truly superb.
I take my hat off to you Sir
Asus Rampage IV Formula
Intel® Core™ i7-3930K CPU @ 4 GHz
G Skill F3-17000CL11-16GBZL @ 2132 MHz
OCZ Vertex 4 256GB SSD
Corsair Hydro Series H100
Gigabyte GTX 690
ganji
VERY NICE! really good attention to detail 😄 the copper and silver looks really good
great job 😄
Thanks a lot bloodycrashboy. 😄
great job 😄
Thanks a lot ganji. 😄
PasLis
I made some progress already and i have leak tested the first loop and its good so on to the next one
A small teaser. 😄
More pictures soon.
