Project - The Next Level - 13-05-2012 Steel and wood
PasLis
Hi Everyone,
Its time for another project.My idea/design to build a desk inside a frame with a glass top and without feet ive done 2 times.
Version 1.
Version 2.
I dont want to make a third version so now its time for a new design.This time i go for an ergonomic design.So this is the kickoff for my new project The Next Level.
The idea is to build a design desk that can be adjust in height so everyone can sit at it by simply push a button to move it up or down.My designs always change when im building so here a drawning how its gonna look.
The desk will be watercooled and the hardware is not decided yett.More about this later.
I already bought the lifting column and this is how it looks.
The specs.
• Thrust: up to 2500 N per DL2
• Speed: up to 20 mm/s with CBD4
• Installation dimensions can be seen in the
ordering example
• Stroke length 300 mm, 350 mm, 500 mm ± 4 mm
• Colour: Natural anodized aluminium profiles and
black painted end plates or electro-galvanised
3 mm end plates
• Low noise level
• Compact and mounting friendly design
• Built-in limit switches (not adjustable)
• Dimension column: 147 x 194 mm
• Dimension 8 mm end plates: 160 x 244 x 8 mm
• Dimension 3 mm end plates: flush with the
profiles
• Each column is fitted with a 740 mm ± 60 mm
straight black cable with an 8-pole AMP plug or
100 mm mini-fit cable
• Dynamic bending moment (at 100% stroke
length):
My+/Mx+ = 250 Nm and My-/Mx- = 200 Nm
And a little movie how it works.
http://www.youtube.com/watch?v=61hPwaFKs1E
213 REPLIES 213
PasLis
Update 26.
I start with putting the desk together and i made some progress.This time i lett the pictures speak for themself.
I also painted the parts that needed to be painted.
The frontgrill.
Some brushing.
Painted it with varnish.
Then i sanded the oak and painted it with bootslak.
More to come. 😄
Thanks to my sponsors :
Just AWESOME !!! I've followed your project since the beginning and the result will be amazing.
Great job ... impatient to see your rig running in that desk 😉
Redback 2012
Case : CM Cosmos II
PSU : Corsair AX1200
CPU : i7 3770k (Swiftech Apogee HD WB)
RAM : 16GB 4x4 Corsair Vengeance Black
MB : ASUS M5F
GPUs : 2x EVGA GTX680 HydroCopper
OS Drive : 120GB Kingston HyperX
Caching Drives : 60GB Intel 520 + 60 GB ADATA XM13
HDDs : 2x 1TB WD Caviar Black
Storage HDDs : 2x 3TB WD Caviar Green
OP : ASUS BW-12B1ST Blu-Ray Writer
Res : Koolance RP-401X2 + 2x Swiftech MCP350 (serial)
OS : WSE 2008 R2 & Linux Mint 13
frisianbear2002
Looking better by the picture ,great job. :cool:
l Asus Rampage 4 Extreme l intel 3930X@ 4800Mhz (1.45volt) 24/7 l Asus matrix GTX 580 l
16GB Team Xtreem DDR3 PC3-20800 2600MHz (11-11-11-28-1)
l Coolermaster Silentpro 1000w PSU l Revodrive3 ssd l WD Raptor 150Gb (10000rpm) l Corsair H100 wc with 4 Cougar Vortex fans l CM HAF 932 Avanced case l Acer X243H 24'' l Asus RT N66U Dark Knight l Logitech Z2300 speakers
In progress the custom build PC Samurai Warrior ''Miyamoto Musashi'' in Japanese ''宮本 武蔵'' made by Pascal
PasLis
Thanks mate. 😄
Nackers
Level 15
I've said before and I'll say it again, beautiful faultless work..
Myk_SilentShado
Level 15
Looks great PasLis!!! are you going to coat the legs with Varnish too, or do you have something else planned for them?
PlaneName
Just looking through this thread, and I got to say it's pretty amazing and exciting to look through all the constructive images and I can't wait to see the finish product!. PasLis, I thank you!, and hope you for the best!.
Case: Antec 300 Mini Tower Motherboard: GA-Z68A-D3H-B3 (rev1.3) CPU: i5 2500k @ 4.5ghz Cooler: Hyper 212 EVO GPU: GIGABYTE GTX 560ti (950mhz) RAM: G.Skill 8 GB DDR3 @ 1600mhz PSU: Corsair CX 750 Driver: 320.00
Been building PC's for 8 Years! 😉
Thanks a lot Nackers.
Thanks a lot Gipe49 and soon the rig will be running inside the desk. 🙂
Thanks Myk and no the columns are anodized so i leave them the way they are now.
Thanks a lot PlaneName.
PasLis
Update 27.
The last 2 weeks i didnt have much time to work on the desk.Busy time is over so back to work.
First i attached the frame to the backside along with the controlbox and the psu.I also mounted the oak backpanel and the new controls for the columns.
The columns were not used fror some time so i did a little test and made a small movie while testing.
Then i mounted the cpu block on the motherboard.
Mounted the reservoirs and the motherboard on the mobotray.
Then i start bending the pipes for the first loop.
The loop is finisht at this point so then i mounted the gpu block and the backplate.
Placed the gpu on the mobo.
Next thing to do is instal the second gpu block and backplate and start bending the pipes for the second loop.
More to come.
Looks nice and sharp.
Really, really love the fusion of High Tech and "old school" wood ... and the black finish of the desk is just a perfect fit with your hardware.
Great work man and waiting for your next updates and rig first firing up 😉
Redback 2012
Case : CM Cosmos II
MB : ASUS M5F
