I got my overall design for this mod when i was designing the lenovo ice build, A smaller compact ice cube made for Gaming !!! but i also really wanted showcase the components. After a few drawings and ordering the materials i was ready to begin.
A Big Thank to Sapphire Tech, & Kingston for letting me build a unique case
Components:Danger Den 7 Slot I/O Shield for Custom Cases
Danger DenMC-TDX Block for LGA 1155, 1156 i3, i5, i7
Danger Den-RAD-Reservoir
Danger Den-CPX-Pro 12V Pump
3/8" Blue UV Danger Den Tubing
Stealth GTS 240 Black Ice Rad
Feser One - UV CLEAR Illusion - F1 - Coolant
Enermax Apollish Vegas 120mm x 25mm
Mod/Smart Supreme System Sleeving
Mod/Smart 20 Station LED Board - Base w/ 10x LEDs
Tailed Red 5mm LED w/ 2 Pin Mobo Header Connector
Bulgin Switch Black Switch - white LED
Silmar 41 casting resin
Fluorescent Acrylic Plexiglass - Blue
Clear Acrylic Plexiglass Sheet - 1/4'' Thick Cast
Sapphire Pure Black P67 Hydra-LGA1155
Sapphire HD6950 Flex
Intel Core i5-2500K Sandy Bridge
Blue Ray Burner
Antec 1200
Kingston 96GB ssd
Kingston hyper 8GB mem
I started by drawing on a wooden sheet for the mold where i want the components to fit.
then i started creating the molds for the base
Poured the resin
after a day of curing in the sun
A rough shell base has begun.
