PROJECT Napoleon Midnight
jmoorez2001
hello all im not new here just a looker bystander i got in to computers a few ( long ago ) and been building them for freinds and family there abouts a friend came up to me one day and said he needed a pc to do revit on and we sat down and thought of the things to go with it we did a few sketches of differnt layouts 32556 and what not's so this is where we started from 32557325583255932560
33 REPLIES 33
jmoorez2001
32629 more pics of the material
jmoorez2001
32635 so we miged the frame turned out great for sure and was much more faster
jmoorez2001
32639cutting m marking radiator fan grills 32640
kkn
Level 14
you have to grind to get away the oxidation on the alu to get a good weld, or else its only going to become a poor one and will break easy or the parts will not join at all.
jmoorez2001
will have a RX480 radiator for the cpu and a rx 240 for the motherboard water block and the ATI pro W9000 video card
jmoorez2001
32645 robert the pc case owner laying out the back plate for the case
jmoorez2001
32648 the other side placed with a few pop rivets
jmoorez2001
32651 installed the front for the hard drive cages then had to order 2 more front 5 1/4 cages so it all would look unform lol
jmoorez2001
32653 testing the psu to make sure it will fit in the opening and added some alum flats around the case fan area's and to the cornners
jmoorez2001
32656 put the top cage around it to make sire it would fit into the cage for the desk and had to grind out the inside corner welds so it would slip over the case better then reweld the top and bottom as when it came from the factory thay only welded the inside of the frame dummy's ill say lol
