06-17-2014
02:26 AM
- last edited on
03-05-2024
10:43 PM
by
ROGBot
06-19-2014 06:17 AM
naj1991 wrote:
verry nice work... the downplate looks realy good... 🙂 need to see the plate of the 5.25 slots when its in position... 😄 *godlike cutting man...
abvolt wrote:
great job looks really good..
MeanMachine wrote:
GDAY DavidNSY, Welcome to ROG and Congrats on a top albeit ambitious project for your first build.:)
Make sure to benchtest your MB and major components prior to assembly, not only to pre configure Bios settings but to ensure everything works just fine. It would be a pain in the proverbial should you have to disassemble your water cooling setup to get at stuff for a simple issue. This has happened to others regularly!!!.
And your English is just fine, keep us updated and Good Luck.
06-19-2014 08:46 PM
06-19-2014 10:44 PM
06-19-2014 11:31 PM
eyeballer wrote:
This is turning out to be one epic build! Loving the workmanship you have been putting into this. Very excited to see the end result - but don't rush 😄
MeanMachine wrote:
Well done DavidNSY, Your doing it like a real pro, Lovely sleeving.
I'm looking forward to the finished product and what you can achieve with an OC.
Just one other thing, Thoroughly flush out your radiators prior to assy.
06-21-2014 09:36 AM
06-21-2014 09:36 PM
06-21-2014 10:49 PM
06-21-2014 11:43 PM
06-24-2014 07:59 AM
MeanMachine wrote:
A truly excellent and meticulous build, You should be so proud DavidNSY
This sets an example and inspiration to others, as to what can be achieved even as a first build.
Now set some benchmarks.
I advise you OC using your Bios and not Windows software, Don't rely on Asus Suite.
Download a copy of ROG Realbench, CoreTemp and its Grapher plugin, HWBot, ROG CPUZ.
For help to OC, just ask, There are top overclockers to guide you on this site,
Thanks for sharing David and Good Luck.:D
MM
