Project BAMF - 1st Water Cooled Rig - Corsair 800D & RIVE
Blitzkreig
Been a few years since I have built a new machine so I decided to also build my first water cooled rig. Build log is a month behind, I started this project almost exactly a month ago. Specs are in my sig.....Some of the mods I made to this Corsair 800D have been done before.
My fan controller from Bitfenix
13648
4 x Spectre Pro 140mm Case fans on the left and 3 x Scythe Ultra 3000 120 for my RAD
13649
Over the next several photos you can see some of the modifications I made to the case. I removed the lower HDD bay and that is now where my Swiftech Dual pumps are setup. You can see 5 1/4 bays have those quick release sliding mechanisms that I did not like at all. I cut all of those off and ground down all the metal clips holding them in place to make the side of the bay smooth for my carbon fiber cover.
13650
13651
13652
13653
I removed the stock front power grouping and installed my own switches, cut the top of it off because it covered the top of the front bezel.
13654
13655
13656
13658
13657
13661
Carbon fiber cover is actually made out of a material used to make knife sheaths and gun holsters called "Holstex" I ditched the screwed on version because I decided it would be a hassle and went with velcro. There where also be a Holstex cover covering up the bottom section of the case so the power supply will not be visible through the 800D's massive side window.
13659
6 sided solid aluminum support brace covered in 3M Di-Noc material
13660
Installing my fans and shrouds. I picked up some Phobya 20mm shrouds and some 5mm LED's to light them up.
13662
Thanks
-Blitz
Case - Corsair 800D Modified
Mobo – RIVE (Bios 3101)
CPU - i7 3960x C2 4.3 ghz
RAM - 32gb Dominator GT 1866 mhz
GPU - 2 x EVGA 680 GTX FTW 4gb
PSU - Corsair AX1200
SSD - 2 x Intel 520 Series 480gb RAID 0
RAID Controller - LSI 9271-8i with Cache Vault
HDD - 600gb WD Velociraptor 10k RPM
Monitor - 3 x Dell U3011 30"
Cooling - EK CSQ Bay Reservoir - EK Blocks (CPU, GPUx2) - Swiftech MCR320-XP RAD - Swiftech MCP35X2 Pumps
7 REPLIES 7
Blitzkreig
I am using High Density Kobra carbon fiber sleeving on everything. Also I pretty much had to order custom screws for everything, I wanted as many as I could get to be black and have a hex head for a specific look I was going for.
13663
13664
Here you can see all the quick release bay clips removed and the panel clips ground down smooth and the new easily removable cover
13665
13666
13667
13668
Still have more work to do. In testing mode now so it's still a bit of a mess. Still need to mount the power supply in the case and sleeve a few more cables.
I will be entering this into EK's pc mod contest in hopes of winning something 🙂
Thanks
-Blitz
ganji
looking very nice so far Blitzkreig, good job 😄
Blitzkreig
and..........done! Here is the finished product of a month+ long project. I love it and am pretty proud for my first water cooled / modded case project. Much inspiration from these forums and other online mod sources but it has a unique touch from myself also. From the carbon fiber material used to make gun holsters to the 1" thick piece of ABS plastic that extends the side panel fan all the way out to the edge, and the front panel mod with the custom switches. The side panel grill was also coated with a material used on firearms and was baked on, super hard and will not chip or scratch.
This sob is heavy! 68lbs!
137711377213773137741377513776137771377813779137801378113782137831378413785
Thanks
-Blitz
Blitzkreig
13786137871378813789137901379113792137931379413795
and.....it's final resting place! can't show it off much behind the monitors, but I'm not complaining! :cool:
13796
Thanks
-Blitz
ganji
Gratz on the finshed build. it looks real nice 😄 now its time to enjoy it 😉
Nackers
Level 15
Goods awesome Blitz, Very clean build...
Blitzkreig
Added my setup to the CooledPC site... EK's contest that is running. If anyone think it deserving please vote!
http://www.cooledpc.com/posts/view/282
Thanks
-Blitz
