New Build - Need help with parts
Fortinbra
I'm starting a new build, and I've started gathering information about my parts.
My ideal build would be a Maximus V Extreme, 3.5GHz i7, 32GB ram, and an ASUS TITAN.
I'd like to liquid cool everything. Does anyone have any recommendations on where to look for a waterblock, or should I consider getting a solid chunk of copper, and doing it myself?
9 REPLIES 9
SKOONJar
This website will help you alot in finding water blocks ive seen everything you need at one point or another on there. http://www.frozencpu.com/
Fortinbra
Thanks, I'll take a look.
Also are you in the united states... forgot to ask. It would help me find you some sources
Zka17
Level 16
Performance PCs is also a good place too look... - http://www.performance-pcs.com/catalog/index.php
Dinnr
If you got the cash you could try EK Waterblocks 🙂
Zka17
Level 16
Both Frozencpu and Performance PCs caries the EK products... :cool:
I made purchases from performance-pc, frozencpu, sidewinder, and koolance never had and problems with them.
x99-pro/3.1 | i7-5820k | 16gb gskils 3000 | Nvidia gtx 980 ti | 512gb SM950 Pro | Predator 360 AIO | ASUS PA248Q | Seasonic Platnium 1000w
Fortinbra
I found all the parts I needed on the EK website. And yes, I'm in the U.S. near D.C. actually.
I have a new issue with my build, I cannot find a mounting diagram for the MAXIMUS V EXTREME MB. It's not in the manual, unless I overlooked it.
Chino
Level 15
There's no need for one. Install the standoffs in your case according for a normal ATX motherboard. The MVE will fit right in.
